Old 08-15-2018, 04:15 AM
Dkatubi06 Dkatubi06 is offline
Default Weird electrical issue
Got a weird one for this thread fellas. Happened three times since February
Including once this morning. Driving to work the radio shut off then half the gauge cluster follows suit. Odd thing is ac will stay on and rpms and tach will function. Loss of shift indicator as well. About a minute or so later everything’s normal. Now the last time it happened I pulled over shit the truck off and tried to restart it it wouldn’t restart just crank and the door locks wouldn’t unlock.
I’m leaning towards the pioneer radio causing it it didn’t do this before I put the new radio in. Just curious if anyone else has this issue. Not really a concern for me unless the truck itself shuts off
2002 GMC 3500 Lb7 converted to LLY, all 2005 electronics. Deleted, studded, 141k on stock bottom end
300k on chassis
Old 08-15-2018, 04:44 AM
TheBac's Avatar
TheBac TheBac is offline
Radio, fuses, or ignition switch.
Moved to Stereo/Electronics, too.
Tom
Old 08-15-2018, 04:46 AM
I have a video of it happening, won’t let me upload it though. I was thinking the radio itself seeing a lot of functions go through it to work, my second thought was the ignition switch as well
300k on chassis
Old 08-15-2018, 04:50 AM
TheBac's Avatar
Did you add any of the modules needed to keep the OEM radio functions when you installed the aftermarket one?
Tom
Old 08-15-2018, 10:04 AM
snowman22's Avatar
snowman22 snowman22 is offline
I would be leaning towards a missing or bad door chime module. Put the factory radio back in and see if the issues come up. The radio itself shouldn't be able to cause the issues described. I've seen missing or failed modules make these trucks do strange things.
2015.5 LML GMC Denali 3500 SRW 4wd CCLB 100k Miles
Mike L Trans, 4" FlowPro, MBRP Down Pipe, 30" FTE Resonator, S&B Intake, Twin Kennedy Pumps, Bilstein 5100, Poly U/LCA Bushings, Kryptonite Tie Rods, EBC Sport Rotors Yellow Pads, Edge CTS2
Old 08-15-2018, 10:24 AM
trashygasman's Avatar
trashygasman trashygasman is offline
Slowly but Surely
I would check to make sure all your fuses are getting good connection. Mainly the ECM fuses. I had the same issue on mine several years ago. Different symptoms but my cluster did funny things and the a/c compressor wouldn’t kick on. Chased that problem for months until I finally found the bad fuse connection.
Kyle
2019 2500HD Z71 Custom Sport Edition L5P
(SOLD)2006 White Silverado LBZ, CC/SB 4x4
EFILive by JoshH, MBRP, S&B, Transgo Jr., AirDog 150, ProFab EGR Delete & Downpipe, Limitless Diesel trans kit w/ 1077 converter
2018 3500HD SRW CCLB 4x4
6.0L gasser (company truck)
Old 09-08-2018, 05:09 PM
I put a new ignition switch an ac Delco one, it did it the next day poked around the fuse box
And all looks clean pulled the box out itself and no chewed wires or such
I’m thinking BCM. So I’m just poking around eBay there’s several up for sale I have a picture of mine for reference. Part numbers are the same, but the bottom numbers are something I know nothing about some of the digits are the same. Then maybe the last for don’t match up.
I know I’ll need a module that is programmed for everything I have pw pl ps ect
Any insight on this one would be helpful
300k on chassis
Old 09-08-2018, 06:09 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
If you find a BCM out of a vehicle with similar options you can just do the relearning process
Take a close look at the large bale connectors. I had a similar problem and found a few pins not protruding out all the way and making contact
2008 Chevrolet 3500HD DRW LTZ
  #9
Old 09-08-2018, 07:42 PM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
Being it's lb7, check for moisture or corrosion at the canbus [2 wires twisted] bridge in bottom drivers kick pannel area. Possibly under carpet there.
I know that was issue which causes weird gauge, radio, or no start issues on those trucks. Caused by moisture collecting off wet boots, poodles in the area where those canbus wires all come together. My GM buddy fixed a bunch of em over the years.
Sent from my SAMSUNG-SM-G890A using Tapatalk
  #10
Old 09-08-2018, 08:18 PM
2004LB7's Avatar
^^ i think I remember something about that. Wasn't the "fix" just removing the padding so moisture couldn't collect there?
  #11
Old 09-08-2018, 08:59 PM
TheBac's Avatar
Wet boots and poodles? Must be raining cats and dogs?
Tom
  #12
Old 09-09-2018, 03:43 AM
kidturbo's Avatar
Piston Tester
Lol.. what i.get for installing taptalk on my phone.
  #13
Old 09-09-2018, 03:52 AM
kidturbo's Avatar
Piston Tester
There is a bulletin on it. Look for poodles while in there... And yeah I think the padding holding water is that issue.
Just unplug and inspect the connectors, spray contact cleaner, and a little grease on em.
  #14
Old 09-09-2018, 08:13 AM
The whole truck is switched over to an lly including All 2005 electronics. And my thoughts exactly on bcm
300k on chassis
