  #1
Old 09-10-2019, 08:49 AM
sneaky98gt sneaky98gt is offline
Gearhead
Default Strange Turn Signal / Marker Lamp Electrical Issue - Need Help
Hello all. I'm having a werid electrical issue with my 2003 Duramax. I'm usually a pretty good troubleshooter, but electrical stuff is sometimes my kryptonite, so I need some help.
First off, here's a quick video showing what's going on.
https://www.youtube.com/watch?v=fQeIrjCUoKk
Basically, with the parking lights on, the turn signal alternates flashing with the side marker lamp. With the parking lights off, the turn signal and side marker lamp flash together. The video doesn't show this, but with just the parking lights on (no signals), the parking lamp and side marker lamp light up as they are supposed to.
All 4 corners do exactly this, and they do it with both the multi-function switch, and the hazard switch. I have verified that all bulbs are good. Activating the brakes doesn't change anything. I unplugged all of the connectors at the rear junction box, and the front lights still do the exact same thing with the rears unplugged.
Before I dive too deep into this, can someone confirm if this is normal operation? A few of my coworkers seem to think this may be normal, but I've always understood an alternating turn signal to indicate (no pun intended...) some sort of problem. And in my experiences on other vehicles, the side marker lights aren't supposed to flash.
Here's my general thoughts:
-No change in the fronts by unplugging the rear junction box would mean there isn't a physical issue in the rear of the truck (short or grounding).
-The issue happening with both the turn signal and hazard switch indicates that it isn't the multifunction switch.
-The fact that all 4 corners are doing exactly the same thing leads me to believe that it isn't an individual physical issue like a bad ground or shorted wire (would seem awfully improbably that 4 different circuits had 4 different, identical failures), but rather something more systemic. Like a flasher relay, or bad BCM, etc.
And that's where my expertise runs out. I have no clue where to go from here, and I hate throwing parts at something. Any input?
Thanks!
  #2
Old 09-10-2019, 08:54 AM
M.A.M.'s Avatar
M.A.M. M.A.M. is offline
Default
Iíd check operation on a totally separate truck. I just about think thatís normal operation.
__________________
2015 CCLB 3500
  #3
Old 09-10-2019, 03:11 PM
Ron Nielson Ron Nielson is offline
Default
What do you see with your headlights on with turn signals? Different? How about DRL's? anything different there?
__________________
Ron Nielson
2008 Chevy Silverado LT, SRW, Crew Cab, LB, LMM/Allison, Rear lowered 2": otherwise, fully stock at this point. Edge Insight CTS
  #4
Old 09-10-2019, 07:00 PM
Gearhead
Default
Quote:
For like 5 days now, I've been scanning the roadways as I drive for another same-body-style truck to see if it does the same or not, lol.
Unfortunately, haven't seen one yet, don't have any close friends with one, and haven't found a single video online yet verifying it.
Quote:
Everything else works exactly as it's supposed to. High and low headlights, DRLs, fog lights, mirror lights, cab lights, license plate lights, interior lights all work perfectly.
I've read through dozens of old forum posts regarding strange tail light / turn signal issues, and virtually always they have some other lights that are acting weirdly at the same time (i.e. bad ground). But this is almost like it's programmed to work this way, as nothing else is amiss. I'm still not convinced that it's supposed to be this way. I think power from the turn signal circuit is feeding through the marker lamps, for whatever reason.
  #5
Old 09-10-2019, 07:32 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
99.9999999% sure that’s normal. I’d check on my 06 but I don’t have marker bulbs in mine anymore. If you think about it, it makes sense. During the daylight there doesn’t need to be a differentiation of pulse because there’s no other amber illuminated. Night time, you already have an amber light, so they are opposite to attract more attention. Might not make sense but it does in my head.
__________________
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #6
Old 09-10-2019, 09:50 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Let me check my truck in the morning. Pretty sure its normal.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 [email protected]
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #7
Old 09-10-2019, 09:54 PM
JoshH's Avatar
JoshH JoshH is offline
Default
It is normal. The reason being is because the side marker light is a single filament bulb that grounds back through the turn signal. When the lights are on and the turn signal activates, it puts voltage to the side marker bulb’s ground which turns it off as the turn signal turns on. When the light isn’t on, the turn signal powers both on and the side marker light grounds back through the wire that normally powers it as a side marker light with the park lights.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #8
Old 09-11-2019, 04:39 AM
zakkb787's Avatar
<thatís not me...
Default
Your description makes a lot more sense Josh lol
__________________
Other toys:
2011 Yamaha YFZ450X
2018 GasGas XC300
  #9
Old 09-11-2019, 04:54 AM
TheBac's Avatar
Default
Lights off --- they work in unison
Lights on --- they work opposite each other
Completely normal.
__________________
Tom
  #10
Old 09-11-2019, 07:41 AM
Gearhead
Default
Quote:
Originally Posted by zakkb787 View Post
99.9999999% sure thatís normal. Iíd check on my 06 but I donít have marker bulbs in mine anymore. If you think about it, it makes sense. During the daylight there doesnít need to be a differentiation of pulse because thereís no other amber illuminated. Night time, you already have an amber light, so they are opposite to attract more attention. Might not make sense but it does in my head.
Completely normal.
Well, I suppose it's never too late to learn something new. I've had, and been around, a lot of vehicles and trailers, and alternating lights always meant that there was something wrong somewhere, usually a bad ground. But, it sure looks like this is how it's supposed to be.
Quote:
Originally Posted by JoshH View Post
It is normal. The reason being is because the side marker light is a single filament bulb that grounds back through the turn signal. When the lights are on and the turn signal activates, it puts voltage to the side marker bulbís ground which turns it off as the turn signal turns on. When the light isnít on, the turn signal powers both on and the side marker light grounds back through the wire that normally powers it as a side marker light with the park lights.
So, I found a wiring diagram, and had some of the electrical engineers I work with help me work through it. What we found was.....exactly what you described. I never would have guessed that it was intentionally wired this way.
In theory, if I wanted it work differently (looking at the left front lamp), I could cut and ground the brown wire coming from the side marker lamp, which would make it always flash with the turn signal. Or, I could cut and ground the light blue wire coming from the side marker lamp, which would make it always on with the parking lights, and not flash at all.
I also combed through the tail light diagrams, and they're wired the exact same way....which means that everything I'm seeing....is exactly how it's supposed to be....
I feel kinda dumb, but I do appreciate the help.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vB.Sponsors
