  #2491
Old 09-05-2018, 09:05 AM
DMAX Slim's Avatar
DMAX Slim DMAX Slim is offline
Collywobbler
Got this Lely done. Bought it from a friend in pretty bad shape. Made the ejector disc out of 1/4 thick stainless. Had the rest powdercoated except for the hopper. Painted it with a brush.
2003 CC/SB LB7 "The Ole Heifer"
1056-Suncoast internals
Built by SMR Diesel Performance
1993 GMC Sonoma 4WD V6 D.D.
Jesus Is The Only Way!
2002 RC/LB LB7~~Sold~~
  #2492
Old 09-06-2018, 08:25 AM
DMAX Slim's Avatar
Collywobbler
Brought the 4630 with me so I can go get new tires put on the back after work. Bad day Saturday with a stick and the right rear.
  #2493
Old 09-06-2018, 02:36 PM
malibu795's Avatar
malibu795 malibu795 is offline
coming home for parts run this morning see a vehicle parted at the end of a driveway with hazards on..driver is on the phone looking at the house found out late we made the call to 911... which I look see smoke coming out the around the garage door... drove around the guy up the driveway, started walking around the house, find a sliding bay window, look inside there was light smoke inside still had 20' visibility .., found an open door get inside clear the house for occupants, no hot doors except the garage to house door.. fire was still contained in the garage, call couple local people, found the tenant(works for couple local farm families, was actually hauling grain to cargil) and land owner(local big farm family) got them notified, checked back later found the wires to the dryer was arcing out had a 220/50A breaker.. never got updated to a 220/40A (newer dryers use less current) wouldn't surprise me if some 4 legged rodents has something to do with bare wires
not so exciting stuff.... got some parts for my c3500HD
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
smooth seas never made a skillfull salior
  #2494
Old 09-06-2018, 05:55 PM
jlawles2 jlawles2 is offline
Guy at work many years ago had something similar happen. Older plugs were more prone to the aluminum wire having issues. I think corrosion gets them.
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #2495
Old 09-07-2018, 10:18 AM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Playing transporter today
03 reg cab. Low and slow
07 crew long classic- stolen
  #2496
Old 09-07-2018, 12:40 PM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
You Could drop that off at my house, I have always wanted one of those. Is it a auto or a Manual?
2001 2500HD Red on Black.
ATS Dual CP3, and S369, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, LBZ/4L80E Inprogress
1967 c30 12v VE/NV4500 tow rig for above truck Inprogress
  #2497
Old 09-07-2018, 12:58 PM
clrussell's Avatar
pro-procrastinator
Auto car. BLAST to drive
  #2498
Old 09-07-2018, 05:48 PM
AZlml's Avatar
AZlml AZlml is offline
We are now required to wear category 2 arc flash gear anytime we throw a knife switch, on or off. So to be on the safe side we fill our paperwork out in full ppe in case the paper bursts into flames
Bryan
11 CCSB 4x4
Full delete, EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
  #2499
Old 09-07-2018, 06:27 PM
Are those cut proof gloves? Paper can take a finger off if not careful. Also that tinted shield is nice so you don't get blinded by the light reflecting off the paper and trip causing you to fall into the switch gear.
  #2500
Old 09-07-2018, 06:37 PM
AZlml's Avatar
If safety hears paper can cut a finger off we'll all be wearing leather gloves, all the time. Or they outlaw paper.. The part I like is the safety glasses worn under the face shield in this particular bag of ppe were so scratched you wouldn't be able to even find the switch let alone throw it..
Bryan
11 CCSB 4x4
  #2501
Old 09-07-2018, 07:05 PM
TheBac's Avatar
TheBac TheBac is offline
Maybe I missed it AZLML, but why do you have to wear that get-up in a warehouse?
Tom
  #2502
Old 09-07-2018, 07:15 PM
Pure Diesel's Avatar
Pure Diesel Pure Diesel is offline
Randsburg Drifter
When I had my solar installed, one guy was wearing that when the panel was opened up. Nobody else was allowed around him.
White GMC 2003 2500HD D/A SLE/CC/SB 4x4] Bilstein 5100~Air bags~Autometer Gauges~33 BFG's~MBRP 4" Exhaust~SD tie rod sleeves~Cognito Braces~Kryptonite upper control arms DMAXSTORE XD TIE RODS~PPE high flow pick up~Fass 95 pump~Titan 52-gal.~Prodigy~New tranny 02/12/2015 Mike L. "Baby Frankenstein " w/Goerend converter w/ Mike L. tranny cooler and pump rub fix~6 speed tap shifter~Siege Engineering Anvil train horns(Very Loud)~LED headlights Hi/Lo
New injectors as of 03/12/2010 @ 80k miles
Injectors started going again at 115k. 07/01/2013
06LBZ engine transplant from Russ @ RPM Motorsports~No more Lb7 injectors to replace
  #2503
Old 09-07-2018, 07:34 PM
AZlml's Avatar
It's an arc flash suit. Our new policy for flipping any knife switch on a 480v control cabinet is to be suited up. We had a panel blow the door off as it was energized at another site. We have about 15-20 control panels for all our various conveyance. Barriers must also be enforced for anyone not suited up around the cabinet. Standard practice for "high" voltage work.
Bryan
11 CCSB 4x4
  #2504
Old 09-07-2018, 09:43 PM
Philv's Avatar
Philv Philv is offline
Nothing like doing a cam block seal on a dd15 in 106. Lol
Sent from my Moto Z (2) using Tapatalk
2001 GMC Sierra 2500HD SLE EC/LB 4x4
LDS 45% SAC injectors
Airdog 4G 165 lift pump
Cold air intake
4" straight exhaust 6" tip
PPE boost valve
Glowshift gauges
  #2505
Old 09-08-2018, 04:35 AM
I missed it and did not get to see the pictures, but power plant I was working at was doing commissioning work and had something in the cabinet come loose. When they racked it back in, the feed fork (technical term here) bent and went directly to ground. Since it was on the incoming feed to the breaker, big light show. I think it was 1350V motor feed. Luckily they were following the PPE procedures and not even an arc flash burn was reported. Probably new undies were needed, but not even a recordable for safety. Following the rules does work for some things.
HTML code is On
