  #1
Old 03-29-2019, 11:40 AM
Jsage99 Jsage99 is offline
FNG
Exclamation New injector and still smoking/over fueling P0304
hello everyone, Im new to the forum. I have a 2008 GMC Duramax had a few issues when i purchased a month ago. I recently replaced injector #4 as my flow rates at idle were +4 and i would continually receive code P0304. Installed new injector and programmed injector flow rates. Problem is i am still blowing excessive smoke and still receiving code and balance rate is still at +4. Zero blow by and compression test was good. Any help would greatly be appreciated!
__________________
2008 GMC Duramax 2500HD. 4" lift. Fass lift pump, Fully deleted, EFI Live DSP5.
  #2
Old 03-29-2019, 01:29 PM
2004LB7's Avatar
2004LB7 2004LB7 is online now
Default
If you have the tools turn off one injector at a time and see if the smoke goes away
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
2006 BRM Jetta TDI. Injectors, turbo, Malone custom tuning on ecm and tcm
  #3
Old 03-29-2019, 01:42 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
because you didnt look at main injection rate.... that may have been your only good injector.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
  #4
Old 03-29-2019, 02:06 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
Compression test it.
__________________
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #5
Old 03-29-2019, 07:59 PM
Ron Nielson Ron Nielson is offline
Default
From ALLDADIY:
Fuel Injector Balance Test with Tech 2
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. See: Testing and Inspection\Initial Inspection and Diagnostic Overview
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
Circuit/System Description
The fuel injector balance test is performed when a misfire, knock, excessive smoke, or rough running condition exists with no electrical DTCs. This test uses the Balance Rate and Cylinder Power Balance test to identify cylinders that are not producing the designed power output. The balance rate adjustments are utilized by the engine control module (ECM) only at idle. The balance rates are the fuel adjustments for each individual cylinder based on the variations in engine crankshaft speed. The balance rates will change depending on if the transmission is in Neutral or Drive. During the Cylinder Power Balance portion of the test, the ECM turns OFF individual injectors while the engine is running. The ECM adjusts for the drop in engine RPM during cancellation and may not change on the scan tool display. The lack of power at the cancelled cylinder will feel like a misfiring cylinder or vibration. If a fuel injector is turned OFF and there is a no difference felt when compared to the other cylinders, that cylinder is identified with the concern. If the customer concern occurs during idle or during off-idle tip in acceleration, the balance rates are used to identify the cylinder with a fault related to the fuel injector or engine compression.
Diagnostic Aids
The Cylinder Power Balance Test may be performed at any engine speed or load from idle to wide open throttle (WOT). There is a 5-minute time limit for each test.
A high balance rate may be caused by a fuel injector or cylinder compression only if the ECM can control fuel pressure.
Circuit/System Verification
Important: If any DTCs other than DTC P0300-P0308 are set, refer to Diagnostic Trouble Code (DTC) List - Vehicle. See: A L L Diagnostic Trouble Codes ( DTC )\Testing and Inspection\Diagnostic Trouble Code Descriptions
Start and run the engine until the coolant temperature is more than 82C (180F). Turn OFF all accessories.
Perform the fuel pressure regulator test, refer to Fuel Pressure Regulator Diagnosis. See: Fuel Pressure Regulator Diagnosis
With a scan tool, command the Balance Rate Monitor ON. Balance rates should be between +4 mm(3) and -6.9 mm(3) in Park or Neutral. Balance rates outside the range may indicate contaminated fuel. Refer to Contaminants-in-Fuel Diagnosis. See: Contaminants-in-Fuel Diagnosis
Important:
The Cylinder Power Balance Test must be performed under the conditions for which the customer concern occurred.
Do not operate the cruise control during this test. Cruise control may cause a brief surge of engine speed after the completion of the test.
Perform the Cylinder Power Balance Test with a scan tool. During cylinder cancellation a noticeable power difference will feel like a misfiring cylinder or vibration.
Circuit/System Testing
Important:
You must perform the Circuit/System Verification before proceeding with Circuit/System Testing.
A fuel injector leak into the combustion chamber may result in mechanical damage to the cylinder. If any fuel spray comes out of a glow plug hole during the compression test, replace the fuel injector of the affected cylinder.
If fuel vapor is emitted during the engine compression test, replace the affected fuel injector and inspect for fuel contamination. refer to Contaminants-in-Fuel Diagnosis. See: Contaminants-in-Fuel Diagnosis
Perform the engine compression test. Refer to Engine Compression Test. See: Tune-up and Engine Performance Checks\Compression Check\Testing and Inspection
If the compression indicated any of the cylinders had low compression, refer to Symptoms - Engine. See: Engine, Cooling and Exhaust\Engine\Testing and Inspection\Symptom Related Diagnostic Procedures\- Symptoms - Engine Mechanical
Important:
Failure to correctly identify the cylinder positions may result in the replacement of the wrong injector.
During replacement of the injectors, inspect the inlet and outlet fittings for corrosion or contamination.
If the engine did not have low compression on any of the cylinders, replace the fuel injectors on the cylinders that had low cylinder power contribution, high balance rates, or a noise/smoke change during cancellation.
__________________
Ron Nielson
2008 Chevy Silverado LT, SRW, Crew Cab, LB, LMM/Allison, Rear lowered 2": otherwise, fully stock at this point. Edge Insight CTS
  #6
Old 03-29-2019, 10:19 PM
FNG
Default
Quote:
what do you mean by main injection rate? I was looking at the balance rates.
__________________
  #7
Old 03-29-2019, 11:44 PM
2004LB7's Avatar
Default
Balance rates are mostly meaningless without knowing the main mm3 unless you run a stock tune and even then it's good to have
__________________
  #8
Old 03-31-2019, 09:22 AM
Default
delete
__________________
Ron Nielson
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vB.Sponsors
