  #16
Old 11-12-2018, 10:47 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
Originally Posted by DAVe3283 View Post
That's interesting, because I've always just scaled the LBZ table to fit the LB7 axis and had good results. It isn't a copy-paste thing, sure, but 5 minutes in Excel with some formulas and it seems to work fine. But that has always been a LBZ regulator on a LB7 CP3, never a full CP3 swap.
Would you mind sharing your table?
My truck has a LBZ CP3 now, but it's a 12mm stroker, so I just made that table up from scratch, for fairly obvious reasons.
I'm on my phone, but I found where I posted it elsewhere. It doesn't vary much, but I know I had to tweak it a little in a few spots.
  #17
Old 11-17-2018, 01:03 PM
Rancelot211's Avatar
Rancelot211 Rancelot211 is offline
Boyd
Crank it up diesel currently tunes it but i will be getting tunes from mark here shortly. Waiting for my hoses and regulator to get here and need to rebuild the filter head. Then i will go from there. If its a weak pump will the lift pump help it keep up with rail until i get a new cp3 or will it not change?
2007.5 lmm Ccsb: 628hp 1237 ftlbs.
06 lbz ccsb sas. 72mm/s483. 10mm cp3. 60 overs and a Bunch of other goodies!
02 lb7 reg cab 4x4. Race truck in progress!
