  #1
Old 03-06-2018, 10:16 PM
GrabAnotherGear GrabAnotherGear is offline
LML/Moto/Boosted Sleds
Default 2012 LML overheating (new) Fan Clutch not engaging P0483
2012 LML totally stock, besides H&S mini-max and Fass 150.
When pulling any sort of load up a grade even in 30 degree weather, the truck overheats (coolant and trans temp) and the fan clutch never engages on high. I can never hear it engage and when I pull over to try and cool it down, the fan is very obviously spinning slowly, not engaged. No CEL, but scanning for codes pulls up P0483 "cooling fan rationality check malfunction". I figured it was a bad fan clutch, so I replaced it from a dealer purchased, brand new clutch... No change. 2 separate new relays... Also, no change. I haven't been able to find any information or schematics/wiring diagrams that are readable to troubleshoot the electro-viscous fan.
Turning the A/C on or whether the truck is hot or not doesn't force the fan to come on. Cooling stack is clean and coolant is pretty fresh.
Any help is greatly appreciated and so would any wiring diagrams for the circuit be really helpful?
Also, would a tech from a dealer likely be willing to plug in a techII and force my fan on to see if it works without charging me labor? (Takes 2 Minutes).
Thanks!
  #2
Old 03-07-2018, 11:19 PM
Default
Thanks!
I went and got a copy of the schematic/wiring diagram from the dealer and took a picture with my phone.... When I figure out how to post it, I will. The fan appears to be controlled by pulse width modulation from the ECM. Maybe the issue is internal to the ECM?
Sent from my S60 using Tapatalk
__________________
2012 GMC Sierra Denali 2500HD LML, stock, H&S mini-maxx (which I don't care too much for), and Fass 150.
(SOLD) 2004.5 Chev 2500HD LLY, go-fast parts, and burning CNG.
  #3
Old 03-07-2018, 11:46 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Stick a meter on it and see what you get. May be tricky without having a reliable way of making it turn on unless you can run some wires into the cab and take it for a drive
If I'm not mistaken, I believe that all it does is power an element in the clutch that causes it to heat up and engage. You can probably check for ohms on this. Dont know what the resistance should be
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
2006 BRM Jetta TDI. Injectors, turbo, Malone custom tuning on ecm and tcm
  #4
Old 03-08-2018, 12:11 PM
Default
LML cooling fan wiring diagram:
__________________
  #5
Old 03-08-2018, 12:37 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
Im sure you checked the ground to the fan and the 10 amp fuse but did you run a jumper across the plug on the coolant switch when eng up to temp ? I have heard of those switches doing strange things and maybe with your tuner it suppressed codes ! Have you tried a Tech 2 yet ?
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #6
Old 03-08-2018, 02:04 PM
2004LB7's Avatar
Default
From the looks of the schematic, there is no way it could be PWM driven. That would make it easier to diagnose. Just an on/off driven relay control
__________________
  #7
Old 03-08-2018, 02:15 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
start tracing wires, bet you got some that are broke. wouldnt hurt to check fuses and the relay as well. a power probe would make diag this pretty easy.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
  #8
Old 03-09-2018, 11:22 AM
Default
When the Tech 2 is plugged in, this is what it comes up with when you try and communicate or command the cooling fan on. Any thoughts? Maybe that GM tech is setting up the tech 2 is a moron? I guess I better start tracing wires.
Thanks for the responses so far.
__________________
  #9
Old 03-09-2018, 10:13 PM
Dallas S Dallas S is offline
Default
Try telling the tech 2 itís a 2011
Itís common practice to run the 2011-2014 on a 4094OS, which is a 2011 OS
__________________
2006 SLT cc/sb LBZ/Allison/np273c D60 SAS 40x15.5r22
2006 LT RC/SB LBZ 4x4
1980 k1500 lq4/4l80/np205 39.5's on a d44
  #10
Old 03-10-2018, 12:22 AM
Scarface39's Avatar
Scarface39 Scarface39 is offline
Gearhead
Default
Have you tried replacing the coolant switch, not sure if its just a coolant level switch or level and temp switch?
  #11
Old 03-12-2018, 02:06 PM
Default
I haven't tried replacing the Coolant Level sensor, although I did jump across it with a wire and there was no change. Even as the truck was running, when I unplugged, put back in the jumper, then plugged it back, no indication on the DIC. Is that weird? Should it have told me coolant-low or something?
Also, I haven't had the chance to try the Tech II again using 2011 as the year.
I may go out and buy a Snap-On Solus edge tonight, if it will pretty much work as well as the Tech II.
Thanks for the input so far!
__________________
  #12
Old 06-27-2018, 02:06 PM
drbird123 drbird123 is offline
Gearhead
Default
Hey did you ever figure this out? Mine is doing the same thing!!!
  #13
Old 06-19-2019, 01:54 PM
Craniumajar Craniumajar is offline
FNG
Default
My truck is doing the same thing. Did you ever get it fixed?
  #14
Old 06-19-2019, 03:51 PM
kiwilml's Avatar
kiwilml kiwilml is offline
Default
The other day I was trying to pull a trailer in some mud and my coolant got pretty hot. Fan didn't come on till around 230 and then shut off right away when cooled down a little. It was sitting at 225 and fan was not on all the way didn't sound like. I'm interested to here some input on this also.
__________________
2016 Chevy LML CCSB.. HSP compound turbo kit with a Stainless Diesel 5 blade S475 over stock. Exergy 10mm cp3 conversion and still on stock injectors and transmission. 5" flo-pro exhaust and then EZ Lynk tuning by PPEI. Also have a 3 pod pillar post with autometer boost,lift pump fuel pressure, and egt gauges.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vB.Sponsors
