  #1216
Old 07-15-2019, 06:59 PM
SoCalMike's Avatar
SoCalMike SoCalMike is offline
Looks good James. Seeing your coil overs makes me wish I went with bds coil over 4.5 inch lift instead of cognito. I just didn't like the 4k+ price tag to go with it. Lol
  #1217
Old 07-17-2019, 10:37 AM
superswamper003's Avatar
superswamper003 superswamper003 is offline
Your putting everything back together James? Sorry for my confusion.
Hendrik
2004 LB7-sold
05 lly cc/sb 4wd
pcv reroute, lbz mp, egr block plate, 5" magnaflow, G2 tie rods, ssdieseltuning, cts2, SDP built trans, pump rub fix, FPRV shim
280k miles
  #1218
Old 07-17-2019, 12:19 PM
Chevy1925's Avatar
Yup!
James
best time to date: 12.39
Tailgate Crew Member #4
  #1219
Old 07-20-2019, 05:37 PM
Chevy1925's Avatar
Doesn’t matter how many times you build an engine, you still get butterfly’s the first time it fires off! Man she idles smooth. Can’t hardly feel any vibs
https://youtu.be/e-RBNWWL9lA
James
  #1220
Old 07-20-2019, 05:46 PM
M.A.M.'s Avatar
M.A.M. M.A.M. is offline
Love that feeling when she starts to get a little fuel and starts sputtering! Sounds good!
2015 CCLB 3500 SWB
  #1221
Old 07-20-2019, 09:45 PM
Burn Down's Avatar
Albert
04.5’ CCSB ole blue, built trans, mpi twins, 12.5X @ 108
99' Reg Cab, 1500 2wd, turbo 6.0, th400 build inprogress
05’ CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60’
  #1222
Old 07-20-2019, 10:24 PM
Potthoffdmax's Avatar
Potthoffdmax Potthoffdmax is offline
EFI live, ARP Studs, shim kit, Afe stage 2 intake, Air Dog 150, Exhaust 4inch, MikeL trans , Autometer gauges, DHD Centerlink Brace, Dmaxstore Tie Rods, pump rub fix.
2017 wrx six speed..
  #1223
Old 07-20-2019, 10:47 PM
Chevy1925's Avatar
She’s about done! Got a long crank issue when starting (may be the fact the second cp3 isn’t hooked up but it’s plumbed), gotta top off coolant, trans fluid and recharge a/c, then go hammer down! My buddy Jon was in town from Michigan so he stopped by to lend and hand and hang out, then my buddy peter stopped by to see him as well. Hence the gray haired wonder photo bombing lol
Now if Wade would quit playing around with tiny coolant parts so I can get that second cp3 spinning
James
  #1224
Old 07-21-2019, 05:06 AM
Mike L.'s Avatar
Mike L. Mike L. is online now
Who's the guy with the beard? He looks happy.
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #1225
Old 07-21-2019, 05:09 AM
SoCalMike's Avatar
Congratulations James.
  #1226
Old 07-21-2019, 08:46 AM
Chevy1925's Avatar
Default Chevy1925 (James) Truck/motor build
Thanks guys and very much so mike! Should we see how far the stock internal shafts last when I start playing with bigger power??
Btw, if you don’t put the ground for the tcm in the right spot, you spend an hour chasing your tail because efi live won’t find the computers and it won’t crank. It blows the ecm fuse that my air dog switched power covers and I missed when checking all fuses lmao
James
  #1227
Old 07-21-2019, 03:46 PM
TheBac's Avatar
TheBac TheBac is offline
What area is your friend from Michigan from?
Tom
  #1228
Old 07-21-2019, 05:00 PM
Chevy1925's Avatar
I’m pretty sure you and Jon have met. I don’t remember what part but he’s not far from you. He’s my Chrysler engineer buddy
James
  #1229
Old 07-21-2019, 05:04 PM
Chevy1925's Avatar
Maiden voyage went well. No bad noises, 55psi I’d boost, 3600rpm, and all temps stayed nice and low. Oil pressure is definitely higher with the melling pump and 20w 50. Idles at 35psi with the truck hot (190* coolant). Very nice. Tune will need some tweaking but I’m going to wait till the second cp3 is runnin. Haze free at idle with these “hazy smokey oval bowl pistons”
James
  #1230
Old 07-21-2019, 06:35 PM
Burn Down's Avatar
Where is that ground James? I have a buddy fighting a weird issue, he should ck that.
Albert
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ChrisPerry
