  #91
Old 10-30-2018, 04:10 PM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
I took it all apart, only hard part added was set of used Crower rods.
At machine shop had the crank and cam key'd, cyls honed, block decked, full balance.
Got new Mahle bearings and rings, cleaned pistons.
All new seals and gaskets and put it all back together.
In short, I have a bone stock shortblock key'd with Crower rods in it.
-Steve Reno- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
  #92
Old 10-30-2018, 04:45 PM
20dmax08 20dmax08 is offline
Gearhead
If a guy wanted to do it himself what’s a good manual to use? Obviously machining going to be added cost. But I’d like to assemble myself.
2008 Chevrolet ccsb 2500 - egr/dpf deleted, pcv rerouted, bd drivers manifold, dmaxstore downpipe, 5” exhaust, s&b cai, arp head studs, htt promax 64, ppei tuned, limitless diy kit installed by me, limitless 1078 converter, goerend Allison deep pan, fass lift pump
  #93
Old 10-30-2018, 05:47 PM
boostwhore's Avatar
boostwhore boostwhore is offline
Drag racer wannabe
Extremely pleased with my SoCal long block, nothing cheap from Guy but his quality seems to be top notch. (Oops was reading page 6 when I wrote this, I don’t know of a good manual for duramax engine assembly)
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, awesome tuning from Aaron at All in trucks.
Best 1/4 to date: 11.06 at 127 in the chase for 10’s.
  #94
Old 10-30-2018, 09:23 PM
SSchmi5519's Avatar
Pro Tuner Wannabe
I used this forum. All the information is here, including the manufacturer specs for clearances and fastener torque.
https://www.duramaxdiesels.com/forum...splay.php?f=97
  #95
Old 10-31-2018, 04:23 AM
Bdsankey's Avatar
Bdsankey Bdsankey is online now
Look into a set of SoCal budget rods also. They are awesome.
As for a manual there is tons of information around on this forum about how to assemble as well as torque specs.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #96
Old 10-31-2018, 12:13 PM
Gearhead
Ok cool. Will have search and print off when time comes I suppose!
  #97
Old 10-31-2018, 12:50 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
http://shop.socaldiesel.com/pages/torque-specs.html
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #98
Old 12-07-2018, 05:01 PM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
Well Bring this threat back to life. I have to replace the water pump, which is going to make me start building the new turbo setup.
Turbo oil drain location.
I was originally planning on putting it in the top oil pan below the Balancer, but then came across wehrli fab putting a bung in the top of the bottem oil pan? Any thought on that location?
Turbo set up, Twins or Triples
I currently have a Pair of S363 from another Project that I can use with a S369, S366, or a modded stock IHI. Or just go the more convectional route with a S475 or S480 over any of the above turbos. I am not dead set on any one set up, I would like some input from tuners, builder, and people that have run any of the above set ups for a opinion.
Going back to the original point of this build is a max of 800HP for a DD/work truck that will tow fairly often. My current S369 will make the power and will do the job that i want. I want to be able to have a family member haul a trailer somewhere and have not having to worry about them melting down the engine.
2001 2500HD Red on Black.
ATS Dual CP3, and S369, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, LBZ/4L80E Inprogress
  #99
Old 12-07-2018, 06:29 PM
gmduramax's Avatar
Shits broke
Ported stock turbo with a S480. And a big oil cooler. 800hp easy
10.98@124mph
Tailgate Crew Member #1
  #100
Old 12-07-2018, 07:40 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
For turbos I would do twins. S480 over S369. Triples are nice but create head aches. As for oil drain tap the front of the upper pan under damper. Makes it way easy to work on it and zero worries about draining.
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #101
Old 12-11-2018, 04:40 AM
lesrrt lesrrt is offline
03 LB7
I am new here, nice read for sure. Has anyone experimented with the 7.1L rotating assembly? Is So cal the only distributor of this? Are the gains worth the costs pertaining to a stout DD
03 171K, 30%/ RDS ups/ manifolds, SB intake, 3.5" horn, ARP studded, stk turbo with PPE valve
PPE Can standard tune #5, stock for now trans, MBRP downpipe and exhaust, AIRDOG, Pending EFI.
  #102
Old 12-11-2018, 05:00 AM
Bdsankey's Avatar
7.1L is overkill for a DD. Awesome setup but for 800ho it’s way overkill.
Current Rides:
  #103
Old 12-12-2018, 06:59 AM
yaba94070 yaba94070 is offline
FNG
Originally Posted by ouellet5 View Post
loll i'm in the same case. I think i will do a ride in states for Black friday
Your not going to save as much as you think. I tried I waited expecting some major savings and not much there. Best deal I saw was $800 of a built trans. 20% of parts purchased
  #104
Old 12-12-2018, 01:15 PM
Bdsankey's Avatar
Originally Posted by SmokeShow View Post
Any of you smart cookies willing to post your ideal (realistic/budget friendly/minimalistic) “recipe” for a reliable 600-800rwhp build like this with your choice of parts & rough prices for each...
Pistons:
Rods:
Cam:
Crank:
Heads:
Fuel:
Air:
Bearings:
Gaskets:
Machining tolerances:
Other:
Pistons: Mahle Race Cast or Delipped LB7/LLY (relief if doing cam)
Rods: Carrillo
Cam: Stock or if funds allow SoCal 6480AF
Crank: Stock that is polished and checked for cracks
Balancer: Fluidampr
Heads: Stock that are cleaned/decked/pressure checked/valve job done with upgraded springs and pushrods
Fuel: 100% over
Air: 64VGT/S480, S364/S480, or a S476/87/1.10 T4 single
Bearings: Clevite H
Gaskets: Victor Reinz Wave Stopper head gaskets and Mahle/Clevite everywhere else
Other: ARP everywhere (head studs, main studs, rocker bolts,flexplate bolts, balancer bolt), billet flexplate, billet injector hold downs
Current Rides:
  #105
Old 12-12-2018, 01:17 PM
Bdsankey's Avatar
I have been thinking about CP/Carrillo Hybrids setup, but also the fact that here isn't a lot of options for cast pistons.
I love my CP-Carrillo hybrid rotating assy. Builds torque like crazy, helps the crank live by pulling 4lb out of the rotating assy, and spools a turbo insanely well (partially due to cam and big fuel).
Current Rides:
