Old 09-10-2014, 08:08 AM
03badmaxxx's Avatar
03badmaxxx 03badmaxxx is offline
Ghost Element
Default Allison Trans-Brake
I decided to move this over to my SunCoast section to post updates easier.
Our initial testing went great and the Trans brake performed as intended. However, there was a cell. Over the weekend we looked into it a little deeper and came up with the solution. Testing commenced this morning and with much excitement, NO cel!
The last few videos are of the new no cel testing
Truck is a 2005 LLY dually with 24' american force wheels, s475 over stock twin kit, NO fuel mods, EFI live, built trans 1057 converter. Sorry for the focus in the vids but i couldn't find our go pros in time. You can see that i'm easily bringing it up to 2500 RPM and have brought it up to 3100 as well ( all with the 1057).
The TB Valve body we are testing in the videos is a 5 speed, we have a 6 speed built as well and will be testing that this week. We also have a controller coming to test with the VB and if all works well, these might hit the market sooner than expected.
https://www.youtube.com/watch?v=_Y7WwdCoZHE
https://www.youtube.com/watch?v=u8WjBvjstNw
https://www.youtube.com/watch?v=axQ-iMIxQ1w
Semi-built motor, ball bearing spinners, fire hydrants, SunCoast COMP trans
Andrew J Murdock
Account Manager // Brand Strategist
The BrandSmith Co.
Andrew@thebrandsmithco.com
Old 09-10-2014, 08:24 AM
DIESELMAFIAPER.LB7's Avatar
DIESELMAFIAPER.LB7 DIESELMAFIAPER.LB7 is offline
<----twinz
I need a like button
2003 GMC CC/SB: billet 66/83mm compounds, dual pumps, exergy injectors, built trans (by me) tuned by me 11.11 @ 124.63mph @ 7100lbs
2012 mega cab 6.7: Tuned and deleted (reliable) sold! (should have kept it)
2016 CCSB custom sport lml ltz deleted with sotf tunes by me
Old 09-10-2014, 08:25 AM
02ilduramax's Avatar
02ilduramax 02ilduramax is offline
Subd
build it til it breaks
2002 lb7 cc/sb afe stage 2 intake, MBRP 5in exhaust, airdog-165, efi live tuned by dans diesel performance, tie rod sleeves, stage 4 trans by mike l
Old 09-10-2014, 08:26 AM
PACougar's Avatar
PACougar PACougar is offline
Andrew, could this be done in a truck that wasn't track only? Being that I have no idea what you guys did internally, I just want to know if it will drive normally otherwise.
2004 LB7 EC/LB 2WD Dropped 6" in the front on coil overs and 7" in the rear on 18"s, Hellwig front and rear sway bars. Caltracs traction bars.
Socal Diesel built bottom end, FI S480 Billet wheel and race cover, RDL Headers and pipes,
Dual Cp3(1 modded and 1 stock), Exergy 100% over injectors,
Socal Diesel injector clamps, Socal Stage 2 Heads/ARP Head Studs
Suncoast GMAX-5 plus some billet built by my best friend Dave(He's a Badass like that), 1058 converter, MikeL Cooler
Mag-Hytec pans on Tranny(Scraping a little) and Diff
Custom modified MBRP exhaust i.e. it dumps in front of the rear tire(Also by Dave). Never had a cat
Labonte Motorsports water/meth, AirDog II 200
Custom 5" Intake Pipe w/AFE Filter, BD Cool It Intercooler,
EFI Live DSP5
Torsen limited slip(POSI), Gauges
DON'T PURCHASE FROM INDUSTRIAL INJECTION UNLESS YOU ENJOY GETTING SCREWED!
Old 09-10-2014, 09:29 AM
03badmaxxx's Avatar
Ghost Element
The truck will drive completely normal with the TB VB. The brake is all modifications done to the VB. So to answer your question, you can put it on any truck. Just hope you never hit the switch while you are moving. Your day will go south very quickly
Andrew J Murdock
The BrandSmith Co.
Old 09-10-2014, 08:40 AM
WisconsinHick1's Avatar
WisconsinHick1 WisconsinHick1 is offline
Also in to learn more.
Green Bean Out
The Rag In
Old 09-10-2014, 09:05 AM
SilveradoTwins02's Avatar
SilveradoTwins02 SilveradoTwins02 is offline
Hopefully twins soon
subd this is interesting!!
Bill
02 Chevy CC/SB 4x4
[COLOR=red]
Motor Build: DeRailed
Bought a 40FT diesel Pusher with a 8.9 Liter Cummins.
everything being sold.
Done :
MA pump rub & DHD TC brace
Total chassis, suspension overhaul with everything new except rear internals.All new brakes, hard and soft lines,UCA's and poly bushings,body bushings
Air bags/ KYB Mono Max shocks
DHD Steering Brace,Rare parts G2 tie rods with self fabbed Idler Gusset.
2012 Chevy Cruze LTZ daily driver
2004 American Coach Tradition 40 FT 8.9 Liter Cummins
Old 09-10-2014, 09:44 AM
So, your saying it is not like the Powerglide T brakes that need to be in 1st gear to operate Where reverse and 1st gear are forced together and when u release reverse backs off? this can be activated in any gear selection?
Bill
02 Chevy CC/SB 4x4
[COLOR=red]
Done :
  #9
Old 09-10-2014, 10:00 AM
03badmaxxx's Avatar
Ghost Element
I'm saying that currently with the revision we are working with you need to be at a Complete stop before activating the brake. This doesn't rule out the possibility of a revision with fail safes in place but it's going to take some time
Andrew J Murdock
The BrandSmith Co.
  #10
Old 09-11-2014, 09:55 AM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Why not just build a little box that monitors VSS, brake pedal, throttle pedal, and boost?
That would be super super easy to make and provide lots of fail-safes.
You could even incorporate launch control in it...so when certain parameters are met, the box releases the trans brake, and away you go.
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #11
Old 09-17-2014, 08:11 PM
dirtracer347 dirtracer347 is offline
Gearhead
This would do away with the purpose of the trans brake. You want to let go of the button when you feel it is time to take off, not when the truck thinks you want it to go. A simple push button would work, just mount it somewhere you won't be prone to hitting it on accident.
2001 EC/SB, 04 front clip, ARP head studs, Trac bars, profab downpipe, EFI, lift pump, ported intake horn
  #12
Old 09-17-2014, 08:43 PM
LBZ's Avatar
LBZ LBZ is online now
x2
You would actually want the opposite. If certain parameters are not met it won't engage for the safety factor - no matter what the position of the switch is.
  #13
Old 09-18-2014, 06:25 AM
<--- slippery roads
At the very least, you would need to have some sort of smart box that requires 0 mph and foot brake applied to engage it....
  #14
Old 09-10-2014, 09:54 AM
TROJAN366's Avatar
TROJAN366 TROJAN366 is offline
Gold Rush
In for more info as it comes available!
05 LLY CC/SB
Roderiques ATV Built Motor, HSP Twins, NLX88/Danville72R,
S&S 200s, S&S 10mm & LBZ, Tuned by Danville Performance
Suncoast Competition trans and Goerend Converter
1125hp/1628lbft 10.52@132
Thanks to
Chris @ Roderiques ATV in Westport MA
Mark Broviak @ Danville
Joe and Dave @ HSPdiesel
  #15
Old 09-10-2014, 09:56 AM
e46_330i's Avatar
e46_330i e46_330i is offline
<3!
LLY CCSB SLT 4x4
*EFI DSP5 By: PPEI *DE Downpipe & 5" Dump *ARP Studded *Pro-Fab Deleted *Custom Re-Routed *Alligator FPRV Plugged *DHD Braced & MA Sleeved *20x12 -44's *305/55/20 Terra Graps *LBZ MP, Intake & FPR *Kleinn Horns & On-Board Air *Paramount Restyling Grill *MA Pump Rub & M1 5w-30 *All-On Mod *Maintained
Willie @ Synthetic Motorsports
Kory @ PPEI
Eric @ Merchant Automotive
Jason @ Alligator Performance
