  #31
Old 06-18-2018, 08:36 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Default
Took it out for it's maiden voyage pulling. Pretty happy with only having the converter locked for ~60ft. I locked it at the last cone after it settled down. Realistically I should have locked it sooner but this was my first pull on a S400, mud tires, and this motor so I was a little conservative.
I've got to say, with the amount of fuel this thing as as well as the way the motor is built pedaling this thing is an absolute dream. It didn't fall off boost ect. I also was unlocked so that probably helped.
https://youtu.be/OzcxQf6J3Fo
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-1340hp/2200ft-lbs @ ATS Diesel (06/04/19)
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Tuned by Starlite
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #32
Old 06-18-2018, 11:22 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Default
Lol well you made it to the end of the track!!!
Pulled strong as an Ox
__________________
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
  #33
Old 06-18-2018, 11:25 AM
Bdsankey's Avatar
Gearhead
Default
It definitely builds tq way different than a friends truck I drove for a few pulls in the open class for points while he was out of town. It also definitely spools better with a similar sized charger.
__________________
Current Rides:
-Tuned by Starlite
  #34
Old 06-26-2018, 07:31 AM
Bdsankey's Avatar
Gearhead
Default Finally Dyno'd
Well, finally was able to get the truck dyno tuned. I ended up going to Duramax Tuner as they are 3 hours from me as well as having one of the best dynos in the country in terms of loading and repeatably.
I understand dyno's are typically tuning tools but I was sure as hell bummed when it only made 820hp on a bullseye batmo S475 with tons of fuel. Then he said tq was 1748ft/lbs and I was blown away with what this hybrid kit was able to do for tq.
At the end of the day it made 820hp/1748tq at 1565us/22deg of timing. I am going to look into getting it dyno'd without the air filter as Bullseye says I am over 100hp low from what it should be. According to Bob @ Duramax Tuner if I went to say Danville or Fleece I would be able to get ~900+ out of it but how far north I don't know.
What I do know is the HSP air filter is sad. It is so damn small for a 5" intake tube. I'm going to pull it off on the dyno Saturday and see how it cleans up for the Hot Shot's Secret Churning Dirt Diesel Truck Challenge.
__________________
Current Rides:
-Tuned by Starlite
  #35
Old 06-26-2018, 08:29 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<that’s not me...
Default
“Only 820” still impressive numbers. Congrats.
__________________
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #36
Old 06-26-2018, 09:09 AM
Bdsankey's Avatar
Gearhead
Default
Quote:
Honestly tho, 820 is pretty low IMO on a billet S475. The TQ is crazy but a little sad with the hp.
__________________
Current Rides:
-Tuned by Starlite
  #37
Old 07-09-2018, 07:24 AM
Bdsankey's Avatar
Gearhead
Default
https://youtu.be/sNhWDWsuzg8
Well finally got a good hook in. Took second behind a remote mount S480/96 T6 with 150% overs, dual 10mm, built motor ect.
This motor sounds so nasty compared to most trucks I've heard. Wondering if thats just AF cam sounds or possibly due to the longer rods?
__________________
Current Rides:
-Tuned by Starlite
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
