Old 03-17-2018, 12:55 AM
bmr7c bmr7c is offline
Gearhead
Default Most Current EGR Delete tables
What's the most current table settings for deleting egr on my lbz. All the hard components are removed off the truck and i just need to adjust my tables. I'm new to EFILive and truck is bone stock. I'm not going to tune it. Just adjust it for the delete
2005 LLY CC/SB - PPE Stage IV trans w/ Precision converter, Air Dog 150, Efilive dsp5 running Idaho Robs tunes, PPE deep pan, Airaid LBZ intake, LBZ mouthpiece, Autometer cobalt egt, boost, trans temp, engine oil temp gauges, Profab turbo downpipe, MBRP exhaust, MA rub fix, Bilstein 5100's, Nicktane kit, manual high idle kit.....
Old 03-17-2018, 03:51 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Turn C2401 to disable. Then go to DTC Test Enablers and set any associated DTC test to "X:Non Reported". Then go to DTC MIL Enablers and set any associated DTC to "No MIL". You can also mess with the B1502-B1505 but you shouldn't need to.
EDIT: I explained the procedure for an LLY because thats what you have in your signature, but now I see you put LBZ in the thread title.
For an LBZ, the disable/enable table is B1501. You can but shouldnt need to adjust B1502 thru B1525 to keep it from running test as well. Then go to DTC Enables and set every associated code to X: Not Reported, No MIL
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Old 03-18-2018, 06:48 PM
Gearhead
Thanks much. I appreciate it. I did a lot of digging and there's threads on this but none are very clear on the best way to do it.
Old 08-17-2018, 01:07 PM
Redneckgt Redneckgt is offline
FNG
know anyone that can tune for the delete for a reasonable price? these $800+ are not working for me.
Old 08-17-2018, 04:05 PM
Slowmax's Avatar
Slowmax Slowmax is offline
Build what others' won't
Where are you located ? Might have a good local tuner in the area.
02 Silverado 4 inch turbo back exhaust with muff, A.E.M intake with cone filter, EFi live.
