Old 08-07-2018, 10:32 PM
Liftemall Liftemall is offline
FNG
Default Crank broke -- need help
So I have an 07.5 2500hd gmc with 60k miles and it spent the last 5 years in the shop getting an insane makeover. After completion I brought her home and put less than 50 miles on her and the crank broke. I am absolutely baffled at how this happened considering the truck has a very mild tune and exhaust upgraded intercooler and Banks torque converter. This truck has 24 inches of lift rolling on 42x16x28. Itís not a truck you can beat on so I canít believe this happened with barely any miles on it. The truck has a total of 60,180 miles. The motor wasnít even broke in yet.
Anyways, I really need some help here. I need an engine completely built that has decent horse power and is 100% reliable. I was hoping to be in the 650hp range. I have zero access to anything to do it myself so I am hoping someone can please direct me to somewhere that can build my complete motor without getting raked over the coals. I would highly appreciate the help in finding a reputable company to build my engine completely to the point of just paying someone to drop it in. I can post pics of this beast if you would like to see it
Old 08-07-2018, 11:49 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Hate to burst your bubble but no engine is 100% reliable. Not even stock or built. Otherwise they'll get infinite miles which we know they don't
Please fill us in on more details about the engine, if more than mentioned above, what was done to it, mods, who's tunes, etc.
Did it sit for 5 years without being run, started?
Give us a little more to work with
2008 Chevrolet 3500HD DRW LTZ
Old 08-08-2018, 02:54 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Originally Posted by Liftemall View Post
So I have an 07.5 2500hd gmc with 60k miles and it spent the last 5 years in the shop getting an insane makeover. After completion I brought her home and put less than 50 miles on her and the crank broke. I am absolutely baffled at how this happened considering the truck has a very mild tune and exhaust upgraded intercooler and Banks torque converter. This truck has 24 inches of lift rolling on 42x16x28. Itís not a truck you can beat on so I canít believe this happened with barely any miles on it!
Where are you located
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Old 08-10-2018, 03:30 PM
FNG
Located in Orlando. The truck was started twice a week and oil change regularly even though it sat. I had a hk tuner on it and full exhaust air intake Banks intercooler Banks torque converter. The shop lost the hk tuner and replaced it with autocal ppei. Picked it up and the truck felt weak. only drove 50 miles total and was not driving it hard. Motor started knocking about two miles from home and 30 seconds later it let loose and died
Old 08-10-2018, 03:57 PM
2004LB7's Avatar
Low oil pressure?
Old 08-10-2018, 04:09 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Harmonic balancer doing the two step dance?
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 8.91@155 5.76@126
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
Old 08-10-2018, 04:33 PM
FNG
Can anyone direct me to someone or somewhere to get an engine?
Old 08-10-2018, 06:48 PM
Blackmax123 Blackmax123 is offline
Depends what you want to spend, there are quite a few vendors on here that can hook you up with a built engine. I'm sure mark at Danville performance, Tony @ DHD, SoCal, or wagler just to name a few can hook you up with a built engine shipped to you.
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- built motor by me, exergy 10mm cp3 swap, danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
  #9
Old 08-10-2018, 08:28 PM
Burn Down's Avatar
PM Shane Phinney he is in Florida and has a shop, he can do it for you or get you set up with a someone trust worthy.
https://www.duramaxdiesels.com/forum/member.php?u=1354
04.5í CCSB ole blue, built trans, mpi twins
03í Reg Cab ZF 6
05í CCSB ole crappy, built eng, built trans, mpi twins
  #10
Old 08-10-2018, 08:42 PM
TheBac's Avatar
TheBac TheBac is offline
I agree -- Shane is probably this person's best bet.
Tom
  #11
Old 08-11-2018, 04:06 AM
NC-smokinlmm's Avatar
<<<Future tuna killer
Sounds like it was broken when you picked it up??
They will still drive, but have low power...
When they break there is a loud pop, or so I've been told. Personally, I think you would have felt or heard something let go way before the knock...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
  #12
Old 08-11-2018, 06:25 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
theres quite a lot of “shops” in our area man but if you can’t put a motor in yourself I would make the drive out to Shane
I don’t trust anyone in this area because I know for a fact a lot of them are just in it for the $$ and the knowledgeable guys just have their crack heads do the work anyways
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
  #13
Old 08-12-2018, 04:38 PM
FNG
I’m looking for something reasonable with 600-650 hp. From what I read, that seams to be the threshold before things get outrageous expensive. If someone can list the contact info for the best engine guy to build this I would appreciate it
  #14
Old 08-12-2018, 06:43 PM
TheBac's Avatar
We told you who to contact in Florida via PM (Shane Phinney https://www.duramaxdiesels.com/forum/member.php?u=1354), unless you want to call Guy at SoCal directly.
Tom
  #15
Old 08-13-2018, 11:02 AM
FNG
Thank you.
