  #31
Old 11-15-2018, 07:41 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Originally Posted by Mike L. View Post
My trim springs don't break.
Indeed. I wish you had invented them a couple years earlier, so my first transmission build could have had them. My current one has them, and so far, so good.
  #32
Old 11-15-2018, 08:04 AM
Chevy1925's Avatar
well get some and put them in! same with the shift valve springs. you will like them
James
best time to date: 12.39
Tailgate Crew Member #4
  #33
Old 11-15-2018, 08:24 AM
DAVe3283's Avatar
I guess I wasn't clear with how I phrased that. My old trans (which blew up from broken trim springs) didn't have the MikeL springs, because he hadn't invented them yet. My current trans does have the MikeL springs, and they are working great.
  #34
Old 11-15-2018, 08:45 AM
Chevy1925's Avatar
no you were clear. im currently running on 3 hours of sleep so things blurred together lol
James
  #35
Old 11-15-2018, 02:11 PM
raceghost's Avatar
raceghost raceghost is offline
Animal
Can I ask what the C2 Hub is and does?
-Raceghost-
2005 GMC Sierra 2500HD LLY SLT CCSB EFI Live/BDGTCLT w/Sensor Dock
Stock Garrett Turbo/2007 Intercooler
AFE Intake/S&B Turbo Inlet Elbow
MBRP 3" Downpipe/4" Straight Exhaust w/Aero Muffler
CP3 Industrial Injection BagoParts/FASS 150 LP w/Sump
SuperTank 52G Tank w/04 Top Half/05 Bottom half Sending unit
RedHead SGB/Cognito A-Arms/Idler & Pitman Braces/FabTech Tie Rods
ProComp Level Keys/Tuff Country Add-A-Leaf
Hellwig HD Front/Rear Sway Bars/SSM 1" Endlinks
FOX 2.0 Shocks/Firestone Ride Rite Air Bags
285/75/16 Nitto Trail Grapplers
  #36
Old 11-15-2018, 02:36 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
It connects the C2 clutches to the P2 planet. They are know to strip the splines because they are made of soft metal.
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #37
Old 11-15-2018, 04:41 PM
sneaky98gt sneaky98gt is offline
FNG
Do the C2 hub. You won't need shafts. If the Allison input shaft breaks it is no problem popping out the broken piece. I've done it many times. No damage occurs to the converter.
Is the stock Allison input hard enough, that it breaks clean enough, that it'll actually come out?
I know my brother's 4R100 builder tried and tried to get his broken input out, but it just wasn't having it. It was hard enough you couldn't drill / tap it, but apparently not so hard that the splines didn't deform just a touch inside the converter, effectively locking it in place.
Out of curiosity, what in the tuning causes the C2 hub to fail? A tie-up where the C2 is applying before C3 releases? Or just a harsh shift and resulting shock load?
  #38
Old 11-15-2018, 05:15 PM
Mike L.'s Avatar
A harsh shift is a tie up. Not knowing how to play with fuel tables will take out a P2 planet and C2 hub on the 3/4 shift.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #39
Old 11-29-2018, 12:53 PM
raceghost's Avatar
Animal
Ok, transmission is ready and about to be installed. I was reading on here in another thread which I cant seem to find at the moment, about when you mate the Flexplate to the converter, extra precautions you take to ensure you don't do something wrong or risk a failure down the road.
Mike, can you give me any of your pointers on the reinstall of a built transmission please. I believe it was one of your posts I was referring to. ANy help would be greatly appreciated.
-Raceghost-
  #40
Old 11-29-2018, 01:14 PM
Mike L.'s Avatar
First, there is one square hole in your flex plate and it should be aligned with the starter opening. Turn the flywheel till it lines up. After you bolt the bell housing to the block, your converter must be free to turn easily. Draw the converter to the flex plate and install your bolt and tighten it. Then do the next 5 bolts.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #41
Old 11-29-2018, 05:09 PM
raceghost's Avatar
Animal
Thanks bud. Any other secrets you wish to share? Also, just a thought. My flexplate is the stock one, has 150k miles on it... Should I be replacing it, upgrading it, worries about reusing it, things like that?
-Raceghost-
