  #5956
Old 10-18-2018, 10:55 AM
ironmax's Avatar
ironmax ironmax is offline
chock full of goodies
I was definitely past 7500, but I try not to load the tongue down. Not the first one I've ripped off either
Sent from my SM-J337A using Tapatalk
air intake
Genuine tornados
4inch turbo back exhaust
bosh remans from lincoln diesel, @290k
fass 150
19.5 american eagle alloys
cognito upper a-arms
Your freedom to be you,includes my freedom to be free from you....
  #5957
Old 10-18-2018, 11:02 AM
ChrisPerry's Avatar
You didn't upgrade to a class v or better after the 1st one failed? Or was it on a different truck?
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE 260 hp tune, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
  #5958
Old 10-18-2018, 11:27 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Originally Posted by ChrisPerry View Post
The factory tow package is rated at 7500 pounds towing and 1000 tongue weight. Its a wonder why they hold up at much as they do with how most people use them.
I upgraded tk a Curt class v a few years back after seeing one fail at the worst possible moment. Totalled the truck, trailer, and offroad rig he was towing. I heard later that the insurance company denied the claim because he was loaded past the receivers rating.
Are you sure about that I swear they were rated for at least 10,000 pounds?
06 GMC 2500 CCSB SLT LBZ 4X4
  #5959
Old 10-18-2018, 11:40 AM
ironmax's Avatar
Diffrent truck
air intake
Genuine tornados
fass 150
  #5960
Old 10-18-2018, 11:45 AM
ironmax's Avatar
Here is what the hitch says
air intake
Genuine tornados
fass 150
  #5961
Old 10-18-2018, 12:39 PM
ChrisPerry's Avatar
I thought so too until I actually read the tag. Still can't believe the hitch is so light weight. I pulled around 12-13000 a few times locally before I knew better. Now that I have a class v, never more than 8000. Go figure.
  #5962
Old 10-18-2018, 04:10 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
They stepped it up on the newer trucks, have to use an insert to use 2" receiver...
HTML code is On
