Old 07-16-2018, 02:12 PM
Chevy1925's Avatar
Default Subwoofer Capacitor
Not really truck related but still automotive related.
In my toy hauler, i installed a 10" Pyle tube style sub that contains its own amp. this one here
https://www.amazon.com/PYLE-PLTAB10-...0%22+subwoofer
yes this thing isnt anything spectacular, i just need some base in the trailer when i crank the tunes up or am watching a movie with the fam. it works good till you go too high volume wise and it starts cutting out.
Issue is the power wire ran back to the subs location is WAY too small. It voltage drops like a mofo when you try to crank it up any. Simple thing is to run a larger wire, right? yyyeeeaaaahhhh that is by no mean going to be simple.
So i had the idea of using a capacitor on the back of the sub to charge up and let the sub run off that when i crank it for a song or two. Will that work or will the sub drain them rather quick?
James
best time to date: 12.39
Tailgate Crew Member #4
Old 07-16-2018, 02:19 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Unless you get a rather large capacitor that’s hella expensive, it’s not going to help a whole lot. Capacitors in car audio are generally just used for bursts of energy when your amp needs it and your alternator can’t keep up for short periods. You could try it tho. It might work decent since it’s not a super high powered system. I’d still get something no less than 10 farad. The higher the better
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
Old 07-16-2018, 02:53 PM
Ridin'GMC's Avatar
Ridin'GMC Ridin'GMC is offline
I like red
Just run a bigger wire and be done with. My white truck has 0 awg wiring. Barely has any dimming with the volume cranked up on a 1000w rms sub/amp. Bigger alternator helps too, although I'm running the stock alternator.
07 LBZ CCSB
RIP 4/1/17
06 LLY CCSB
Old 07-16-2018, 03:25 PM
Chevy1925's Avatar
its not that easy or id have done it When these MFG run all the wiring, its all done prior to the walls going up. Genesis does it some other sneaky way through the roof as well and you cant run it through the walls (they are solid walls). The sub is up above the head unit above the dinette. id have to somehow get the wire from the batteries (at the very front of the trailer), through the wall or roof, over the door and down into the cabinet the sub is on. about 20 or more feet of wire is my guess.
if the capacitor wont work, ill have to figure out a way to mount it under the stairs but that kills my plan for putting a winch under there for the sand car.
James
Old 07-16-2018, 03:58 PM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
Call me lol
-Steve Reno- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
Old 07-16-2018, 04:08 PM
snowman22's Avatar
snowman22 snowman22 is offline
Had a similar issue on a trailer a while back. I had a 12v gel motorcycle battery sitting around and put it next to the amp, problem solved. A capacitor is for huge discharges and fast recharges, not for a sustained load.
2015.5 LML GMC Denali 3500 SRW 4wd CCLB 95k Miles
Mike L Trans, 4" FlowPro, MBRP Down Pipe, 30" FTE Resonator, S&B Intake, Twin Kennedy Pumps, Bilstein 5100, Poly U/LCA Bushings, Kryptonite Tie Rods, EBC Sport Rotors Yellow Pads, Edge CTS2
Old 07-16-2018, 04:35 PM
gmduramax's Avatar
Shits broke
Put a battery by it. Capacitor probably won’t work.
10.98@124mph
Tailgate Crew Member #1
Old 07-16-2018, 04:39 PM
Chevy1925's Avatar
Originally Posted by gmduramax View Post
Put a battery by it. Capacitor probably wonít work.
Thatís a good idea. Put a little battery box up there and Iíll get some UPC batteries from my brother. That should work!
Originally Posted by SSchmi5519 View Post
Call me lol
No, you wonít pick up!
James
