Go Back   Duramax Diesels Forum > Duramax/Diesel Technical > Duramax Hard Parts > LB7
Notices
Thread Tools Display Modes
Old 05-11-2020, 07:14 AM
DuramxMan's Avatar
DuramxMan DuramxMan is offline
Gearhead
Default LB7 Pushrods
Well rod broke and building another block and bent a few push rods. What are best push rods to buy. Motor pushing 800hp.
2004 Chevy 2500HD CC 4WD LB7, Studded Heads , DTS 67 mm turbo, 10mm Stroker Pump, 45 over injectors, FASS 150, MBRP 3" Downpipe, 4" MBRP Exhaust, DTS Built Trans, Suncoast 1073 Torque Convertor, Tie Rod Sleeves and Solid Centerlink, QA1 Shocks Best 1/4 mile 11.38 at 118mph 60 ft 1.611
Old 05-11-2020, 07:17 AM
Chevy1925's Avatar
more a matter of what valve springs you are running and rpm.
James
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
2002 2500HD CC/LB dmax/6sp alli "The Limo" SOLD - Gone but not forgotten
Tailgate Crew Member #4
Old 05-11-2020, 07:21 AM
DuramxMan's Avatar
Gearhead
Has stock springs and running 3300 rpm, but may turn that up. Replacing pistons with 0.020 over diamond cast pistons with valve reliefs. May need to change springs also?
Old 05-11-2020, 07:38 AM
CHEZELTINE's Avatar
CHEZELTINE CHEZELTINE is offline
Gearhead
My merchant's are holding up in my stock engine. Probably not the info you're looking for but that's all I have on pushrods haha.
Sent from my ONEPLUS A3000 using Tapatalk
03 CC/SB, AD4G165, EFI LIVE, A BUNCH OF DUMB BOLT ON'S AND 64MM DROP-IN BIG THANKS TO BURNDOWN.
Old 05-11-2020, 08:05 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
I'm running SoCal without issues and my daily driver will be getting them as well.
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
-Built Motor, Triples (2x S369 over a 472), F1 Diesel 300% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend Bolt Together Converter, Billet Trans, Banks Intercooler, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Built Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
Old 05-11-2020, 08:53 AM
Chevy1925's Avatar
again, depends on what RPM you want to turn, where you want the power band with turbo/s, what kind of head and cam setup and converter you want to match with.
if you are going base with stock springs or say, the light hamilton springs, the hamilton pushrods (thinnest ones) will be plenty.
Personally, i wouldnt just add the thickest pushrods and call it good. Thats more weight on the valve train thats not needed and wont help you in high rpm.
James
Old 05-11-2020, 10:47 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
For what it's worth, I'm running SoCal beehive valve springs, shift at 3600 RPM (with occasional blitzes to 4800+ RPM during burnouts), and I'm on stock LB7 pushrods.
The stock pushrods are designed to run the stock valves at ~4800 RPM during engine braking, and are actually pretty strong. I'd imagine you only bent yours during the engine failure.
Old 05-11-2020, 12:17 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Merchant ones here
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #9
Old 05-11-2020, 01:01 PM
JoshH's Avatar
JoshH JoshH is offline
I would be upgrading valve springs before I worried about push rods.
06 Silverado 4x4 CC/SB
  #10
Old 05-12-2020, 06:14 AM
KyleC4 KyleC4 is offline
What’s the weight difference between the aftermarket and stock pushrods ? Curious
Concord Chevrolet
Mike L and Inglewood transmission
  #11
Old 05-12-2020, 08:52 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
This^.
If you have to, merchant's are the best bang for your buck without getting heavier than needed. We used them at 16xxhp and ran down the track 5500 rpm. Big engine builders will recommend .145 wall pushrods for extreme app's but .083 served us well time after time.
Years ago, we had trouble with Hamilton's push rods. Bought his springs and pushrods, springs did well for us, still in an engine. But the pushrods were too short, to the point that the adjusters had to be wound way out to account for it. I didn't like the angle it produced, so we shelved them.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
