  #31
Old 04-01-2018, 06:54 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Quote:
Originally Posted by OregonDMAX View Post
fit several rv's in a shop with 14' doors dunno what kind of antennas you putting on your rv
I've rigged a few for customers but they were old Prevost busses converted with full slide outs and every emenity you can squeeze into one. They are pretty neat, you would never know what it was going down the road. Antenna wise KVH, XM weather/audio, wifi booster, etc. They are a challenge to rigg bc of top crowning...
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900 @ 14#'s, BTR Top End Boosted Bump Stick, Trunion upgrade, 90mm, 10% over, 2.8 griptec, 105 lb ID's, Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #32
Old 04-02-2018, 08:30 AM
matt78 matt78 is offline
Finally boosted launches
Default
Quote:
Originally Posted by AZlml View Post
How thick is the concrete?
4 inch,red select dirt pad,one main beam across and 1/2 rebar. Thought about 5 but didnt do it. Also i paid for the dirt pad out of pocket so it was not in the 60k.
__________________
2015 ltz 3500. 97 monaco bus. 2016 2500 gassee. 2001 burb.
  #33
Old 04-02-2018, 08:43 AM
Bdsankey Bdsankey is offline
Default
Quote:
You will be hard pressed to put a lift in a 4" slab, it will spider crack in no-time.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Bosch Reman Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, Beans Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #34
Old 04-02-2018, 08:46 AM
Default
Quote:
Didnt say i was adding a lift. There is a 41 ft monaco bus in there,seems fine.
__________________
  #35
Old 04-02-2018, 10:04 AM
joshd472's Avatar
joshd472 joshd472 is offline
Default
All of it cracks eventually. Best the thing to do is put expansion joints around the lift.
  #36
Old 04-02-2018, 11:25 AM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default
For the lift, just cut out an appropriate sized square opening in the slab and pour a suitable isolated footing.
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
