  #16
Old 06-16-2015, 07:26 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default
You need to compare apples to apples. That is, you need to compare the same chamber size, compression height and bore for it to be meaningful. Just telling you a weight doesn't mean much.
__________________
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #17
Old 06-18-2015, 09:34 PM
Mikey's Avatar
Mikey Mikey is offline
Drag Racer
Default
My brother works for Ross and they make Pistons that work with a lighter top fuel pin and aluminum rods
__________________
__________________________________________
2007 CC/SB GMC SIERRA CLASSIC
2WD
Suncoast 1058
EFI LIVE
FASS 150
CALTRACS
12.73 @ 100 mph (Fontana)
8.10 w/ 1.82 60' (Irwindale)
TWO WHEEL DRIVE, 6" LIFT 35" Tires
ANYONE FASTER?
  #18
Old 06-26-2015, 09:05 AM
02ilduramax's Avatar
02ilduramax 02ilduramax is offline
Default
so im thinking im going to go with arias with a lower c/r just still cant decide 100 percent everyone I talk to says something different I just want to build it right the first time
__________________
build it til it breaks
2002 lb7 cc/sb afe stage 2 intake, MBRP 5in exhaust, airdog-165, efi live tuned by dans diesel performance, tie rod sleeves, stage 4 trans by mike l
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
