Old 06-28-2018, 03:18 PM
fl0w3n fl0w3n is offline
Gearhead
Default Rebuilt ZF6 price check/rebuilder check
My ZF6 was feeling kind of tired already, and then I went and completely destroyed my tail housing.
I’m not able to find a replacement tail housing, and it’s so bad I doubt it can be repaired. I’m worried even if I found a tail housing or somehow fixed mine, I did a lot of driving on it while it was broken and could have done other internal damage.
I found a company in Arizona that has a strong sales pitch, guy who locally has been rebuilding trans for 40+ years and is “known” by the locals as Red, the go to guy.
Price is $1,850 + $500 core, they keep $200 for my damaged tail housing, and $125 for shipping. 12mo/12k warranty. This is the place
http://www.mwdauto.com/mtd/about-us/
They say mainshaft, syncros, shift forks, seals, main carrier bearings are all new. I believe they said other bearings are checked and replaced as needed. Obviously any other internals like gears are replaced as needed. No fluid included, no sensors etc, shifter/tower is reused from old one, no clutch and no flywheel. Just the bare unit.
The price seems great, but I’ve never had a trans rebuilt before. And there is the classic saying, you get what you pay for. Is the price too good? Anything else I should ask about or look into?
Unfortunately I wasn’t budgeting to do this, and adding in a clutch and flywheel will make it a pretty penny.
2002 LB7/ZF6 CCSB Sierra 4x4
340k miles
Stock...for now
Plans:
KP D60 front, ORD leafs front/rear, Twin Stick NP205, 4.56 gearing locked rear, PSC steering/hydro assist , 37"s on H1 wheels, Titan or Aerotank replacement
SAC45% Injectors, SB SD clutch, Kennedy pump and filter heads, S&B intake, ProFab up/down pipe, manifolds, Mild Tune from Rob
Old 06-28-2018, 03:33 PM
Gearhead
The other thing I would add is with the help/tools of the guys at the shop my company has, they could guide me through rebuilding the trans I’m sure. But that again depends on finding a tail housing, and not severely damaging anything else internally.
For the $2k price, would I really be saving that much assuming I’m even able to find the parts?
340k miles
Stock...for now
Plans:
Old 07-23-2018, 09:05 PM
48548 48548 is offline
Gearhead
What did you end up doing?
Sent from my SM-G955U using Tapatalk
Old 07-24-2018, 07:27 AM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
There is a guy I know that builds these diesel manuals in his sleep, I have dipped into the 10s on his transmissions. And have handfuls of low 11 second slips. I could get you a price for a stock rebuild but good luck on the tailhousing. Guy on Facebook is talking about making billet tailgousing for like 2k but isn't done yet.
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
Old 08-01-2018, 03:17 PM
Gearhead
Wound up ordering the trans from them... and the fricken sales guy totally biffed it. Despite talking about ZF6 and the tail housing and what I wanted etc etc, he barely gave any info to the builder and they shipped me an NV4500 for that price.
However, he did right on his side and searched and got me a rebuilt ZF6 4x4 for $3250 flat. I go to pick it up next week.
I was on the strictly ZF6 Facebook group looking, but nothing really came of it.
340k miles
Stock...for now
Plans:
