  #1
Old 08-22-2018, 12:50 AM
801duramaxxx 801duramaxxx is offline
FNG
Default 2001 LB7 is my Trans toast?
Hi, I'm new to the forum Ive searched every forum that i can find on this issue and have tried all the tricks and recommendations. I've just recently bought a 2001 lb7 duramax with the 5 speed allison. I got the truck real cheap and had no idea if it even ran. (Repo truck) batteries were toast and i had 1 good one that fit so i put that in and got her to start. I tried to put the transmission in gear and reverse works as it should but there are no forward gears working. At this point I've went over the harness and all the wiring up to where it goes up into the engine bay and can't see any bad wires. The Transmission is not setting any codes, I've tried unplugging the NSBU switch and main transmission connector (try to force it into 3rd gear limp mode) and replaced the turbine speed sensor because it was not reading anything.
I have HP tuners and when i have the scanner running the computer can see what gear the selector is in (dashboard is blank and I'm assuming its the cluster) and also shows the gear the transmission is commanding and they all show correct. in all forward gears the transmission is commanding 1st gear for a couple seconds and then commands neutral.
Dropped the pan to take a look inside and the fluid didn't look to bad but there was some debree, pretty good metal shavings and a small amount of sludge on the magnet.
I jacked the truck up off the rear wheels and reverse was working fine and then suddenly stopped. put it in neutral and back to reverse and it was working again and didn't have an issue. (just idling) but when i put the truck into any of the forward gears the tires move forward maybe an inch very slowly and then stop moving. Im starting to think that this may be a mechanical issue inside the transmission. Maybe a stuck valve/Solenoid not operating properly? should i be looking into a rebuild for the trans?
I'm not really sure where to go from here anyones input on the situation is appreciated.
__________________
1991 k1500 6" on 35's, lm7 swap, nv4500, cam, tune, Full boltons
2001 Duramax 2500hd, 6" on 35s, bolt ons, Intake, Exhaust, edge juice with attitude.
1994 dodge ram 2500, CTD, bone stock
1997 Toyota 4runner, work truck 3" on 33's
2010 Silverado 1500, 7.5" 35's, bolt ons, tune, Girls DD
  #2
Old 08-22-2018, 04:30 AM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Default
Sounds like your C1 clutches are toast to me
__________________
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #3
Old 08-22-2018, 09:47 AM
FNG
Default
That’s what I was afraid of is the Allison a very complicated trans? I’m pretty mechanically inclined and not afraid to tear stuff apart on my own but I’ve never rebuild a transmission would it be a good idea to tear into it and see if I can replace the clutches myself?
__________________
  #4
Old 08-22-2018, 09:53 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
You'll need more than clutches.
__________________
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #5
Old 08-22-2018, 10:14 AM
juddski88's Avatar
Freedom Diesel
Default
Typically when you see a lot of metal shavings in the pan, and you have the symptoms you have, you can bet that the sump filter is pretty plugged, which starves the entire transmission of fluid quantity and pressure, which causes excessive heat throughout, and makes quick work of destroying the converter, and the majority of the clutch packs in the trans, and also the seals, bushings, and bearings. It requires an extensive, complete thorough cleaning and rebuild, and you're heat exchanger cores should be flushed out also.
__________________
Thank you.
  #6
Old 08-22-2018, 10:26 AM
duramax on fire's Avatar
duramax on fire duramax on fire is offline
Default
I would take it to someone that really knows them. I wouldn't dare tear into one. Also read up on the housing. If I remember right they cracked on the front bell on the 01s. Might want to upgrade it while your in there.
  #7
Old 08-22-2018, 07:57 PM
FNG
Default
Thanks guys for the replies. I'm just gonna get to pulling the trans and having it built by a reputable shop. or maybe even order a reman unit but i want something that will handle a decent amount of power like a 200hp tune nothing crazy. heaviest thing i own is a 10,000lb max gvwr toy hauler that ill tow around occasionally, right now i tow it with my LS 5.3 swapped k1500 with a few mods to beef up the drivetrain, brakes and suspension and it does alright but i only get about 6mpg with the trailer hooked up around 8000lbs Im in Salt Lake City does anyone have any recommendations on where to get a reman unit or what shops to check out around my area.
__________________
  #8
Old 08-23-2018, 05:12 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
Contact Evan at limitless diesel.
__________________
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #9
Old 09-05-2018, 11:12 AM
FNG
Default
well heres an update. i tore the trans out figured shops charge to much so id save myself some cash and ended up building it myself (first time I've ever looked inside an automatic transmission) my buddy had a book for allisons and i added a transgo jr shift kit, alto red clutches, and billet TC. it drives awesome now and shifts through all the gears perfect. the 2-1 shift is a little harsh though. just got it all back together last night and I'm trying to figure out if i can reset the TAPS through my HP tuners vcm scanner.
what are the other options for reseting the trans and putting it into fast learn mode??
__________________
  #10
Old 09-05-2018, 11:31 AM
darkness's Avatar
darkness darkness is online now
Default
That 2-1 could be harsh. The ‘01 os is prone to that. Especially if it’s cold.
You might need a tech-2 to reset the pressures.
__________________
Rob
2004 2500hd GMC. Mike L. trans, EPR twins. 620hp/1100tq. bought new in June 2004. Sold on 12/28/16 .
2007 classic 2500hd Chevy (Blacula) bought 3/16/18.
Rare parts steering w/DHD brace, egr delete, pcv re-route, BD lift pump, duramaxtuner perfect tow tune.
  #11
Old 09-05-2018, 11:43 AM
Mike L.'s Avatar
Default
The '01 OS can take its sweet time learning. It's the dumbest OS out there.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #12
Old 09-05-2018, 04:45 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Yep...
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #13
Old 09-05-2018, 05:23 PM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
Does HP tuners support full flashing AL5?
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
8.17@84mph 1/8mi
Jesse
  #14
Old 09-05-2018, 06:03 PM
duramaxnate's Avatar
duramaxnate duramaxnate is offline
Professional Amateur
Default
Quote:
I do believe so yes. I can confirm when I get back to the shop. I have hpt on my computer
Sent from my XT1650 using Tapatalk
__________________
RIVCO MOTORSPORTS
WWW.RIVCOMOTORSPORTS.COM
SOCAL DIESEL TRUCKS
WWW.SOCALDIESELTRUCKS.COM
-"Casper" 2005 GMC LBZ ECSB
Best Time: 10.59 @ 128 (Kat Driving)
9s......loading..........
-"Betty" 2006 GMC LBZ CCSB
Best Time: 12.70 @ 104
Not going any faster.
Thanks to all that helped me
- The McRats
- Mike L @ Inglewood Transmission
- And many others
  #15
Old 09-05-2018, 07:57 PM
Mike L.'s Avatar
Default
Why would you full flash it? Doesn't affect the adapts.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
