  #1
Old 06-19-2017, 07:52 AM
cm2500hd cm2500hd is offline
FNG
Default Allison extension housing replacement procedure
ok guys I have a cracked extension housing. I know I have to pull the trans to fix it but Im looking for more information on how to do it?
thanks
  #2
Old 06-19-2017, 12:10 PM
JoshH's Avatar
JoshH JoshH is offline
Default
Drain fluid
Remove transmission
Remove torque converter
Stand transmission with tail housing end up
With transmission in park, remove output shaft nut
Remove tailhousing bolts
Remove tailhousing making sure the park pawl pin doesn't try to come up with the tailhousing
Remove old tailhousing gasket
Remove C5 apply piston if your new tailhousing doesn't come with one
Install new lip seals on C5 apply piston
Install piston into new tailhousing
Place new gasket on rear of transmission
Install new tailhousing
Torque bolts to 42 lb-ft
With transmission in park, install output shaft nut and torque to 45 lb-ft
Stand transmission with bellhousing up
Measure input shaft end play (I usually shoot for around .035")
Correct end play as necessary with shim under output roller bearing
Lie transmission down
Install torque converter
Install transmission in truck
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #3
Old 06-19-2017, 12:17 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Josh, make this a sticky here. Save a lot of time and trouble for us.
__________________
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
