  #1
Old 12-05-2018, 06:06 PM
happyhuero happyhuero is offline
SoCal
Default 2001 injector problems
I have a Silverado 3500 2001 that needs to replace injectors. #3 and #7 are the bad ones but will replace all 8. My question is what brand injector is the best and what is the price average in labor and parts? What is LLY injector?
  #2
Old 12-05-2018, 06:22 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
Quote:
You cant put a lly injector in a lb7 head. You would have to swap heads. You can get the injectors straight from the dealer or LDS. If you don't want to tackle the task and want someone else to do it let us know where you are located so everyone can recommend a good local shop
__________________
09 lmm ccsb ltz, moonshine, mpi s480 over 68mm vgt, sdp y bridge, BigDipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on...Big thanks to BigDipper!
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #3
Old 12-05-2018, 06:28 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
Just go to SOCAL and get it done right !
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #4
Old 12-05-2018, 06:40 PM
Default
Disregard last post I am not sure if they install . I just tried to call and they were closed . I am sure someone knows places in your area and will chime in , sorry !
__________________
  #5
Old 12-05-2018, 06:48 PM
Default
JAMES do you do work for others at your shop or is it just your own stuff ! I just asked so I will know to send people your way if you do ! You seem very knowledgeable about these trucks !
__________________
  #6
Old 12-05-2018, 07:21 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Bosch brand injectors only.
Find a reputable installer.
Lincoln diesel is a great place to buy and also a site vendor
__________________
03 reg cab. Low and slow
07 crew long classic- stolen
  #7
Old 12-05-2018, 07:22 PM
TheBac's Avatar
TheBac TheBac is offline
Default
^^^ Listen to all of what CRussell posted.
Moved to LB7 section.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #8
Old 12-05-2018, 09:37 PM
The Kansan's Avatar
The Kansan The Kansan is offline
Default
Ive had good luck with the NEW Merchant LB7 Injectors. They are brand new bosch fully updated. And there is no core with them.
__________________
-2003 CCSB Silverado-
LB7 Died 6/10/17 3 Bent Rods 1 Cracked Piston
LLY Swapped
LBZ Rods
LB7 Crank & Pistons
Built by me
63mm VGT
Kryptonite
Wagler AF Cam
Built SC Trans 1074
HSP Billet Y Bridge
HSP Intake
HSP Billet Thermastat Housing
Fleece 10mm CP3
Spearco Intercooler
PPE Man & Up Pipes
All Cerakoted by Me
Real Built Motor Coming Soon
  #9
Old 12-06-2018, 07:09 AM
Brent@LDS's Avatar
Brent@LDS Brent@LDS is offline
Default
We can get you taken care of here at Lincoln Diesel for all your injector needs. Make sure you stick with a OEM Genuine Bosch injector. We have several options here and will get you taken care of! Let me know if you have any questions.
__________________
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-361-7700
  #10
Old 12-07-2018, 12:05 PM
Default
I think he is wanting someone to install them near southern cali , that is why I asked if James dose work for others outside if his own or friends ?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
