  #76
Old 12-05-2018, 05:19 PM
Potthoffdmax's Avatar
Potthoffdmax Potthoffdmax is offline
Wow!! That’s amazing
EFI live, ARP Studs, shim kit, Afe stage 2 intake, Air Dog 150, Exhaust 4inch, MikeL trans , Autometer gauges, DHD Centerlink Brace, Dmaxstore Tie Rods, pump rub fix.
2017 wrx six speed..
  #77
Old 12-06-2018, 05:13 AM
darkness's Avatar
darkness darkness is offline
That’s clean!
Rob
2004 2500hd GMC. Mike L. trans, EPR twins. 620hp/1100tq. bought new in June 2004. Sold on 12/28/16 .
2007 classic 2500hd Chevy (Blacula) bought 3/16/18.
Rare parts steering w/DHD brace, egr delete, pcv re-route, BD lift pump, duramaxtuner perfect tow tune.
  #78
Old 12-06-2018, 05:42 AM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
I like it a lot!
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Custom 80" Trac Bars by MBS Diesel
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to:Scott@SDP
Tuned by:Blake@UDT
Best time to date: 12.08 @ 112.58 1.76 60ft
  #79
Old 12-06-2018, 04:51 PM
Burn Down's Avatar
Just keeps getting better and better Rick
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #80
Old 12-06-2018, 08:43 PM
rfletes79's Avatar
rfletes79 rfletes79 is offline
Thx you guys. Someday I might actually have a ‘built’motor for her. But for now we just keep on flogging the stock shit. Lol.
This intake is something else, not sure who on here has one on an LB7 but holy crap. It’s quite the task to make it work. I thought it was pretty straight forward, specially since I already had custom fuel return lines. That helped but it still needs a lot of changes besides the return rail.....
The car is ready for testing. I’ve put some miles on her the past couple days here in town and a couple hits on the back roads. Feels good. We got very creative with the fuel temp sensor. So far it’s working well in its new home. I’ll have more data Saturday and will post the details then.
j
1970 Chevelle Duramax Hot Rod, '04 LB7/TH400-gear vendor, HTT 67.7 FMW, Wagler street intake, 65% S&S sticks, exergy 10 mil pump, SoCal AF3388, Valve springs, Push Rods, LBZ rods, cut LB7 slugs..... 10 sec cruzer :-)
2002 2500HD LLY 6 speed ally conversion
  #81
Old 12-07-2018, 07:53 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Dont let it fool you. Just like many of Waglers products there is not much info on it. Even on a LBZ it takes some modifications to make it work. Jeremy said they are working on a install kit. But we will see
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #82
Old 12-08-2018, 06:49 PM
rfletes79's Avatar
First trip out to the track with the new setup. Had some issues with a pretty good size exhaust leak, pretty sure I narrowed it down to the up pipes/pedestal but fought it all day and smoked the lights 4 out of 5 runs...….. sucked, I haven't done that in years.
The one pass I got in without smoking the lights it ran a 10.61@126 with a 1.49 60' It went a better 60' on a previous pass but with a smoked timeslip, was prob a 10.50ish is what I estimate...……
All in all was good, Ill fix the leak and go again. I'm sure it has some 10.40's in her or close to it. Which is better then the compound setup that just came off. I'm happy with it.
j
  #83
Old 12-08-2018, 06:55 PM
rfletes79's Avatar
So last year when I made new fuel return lines I just laid the fuel temp plug and sensor on the intake (clamshell) and just zip tied it to the harness, it just picked up whatever temp it could while just laying there, worked fine no issues.
With this new combo I was very curious as to what the intake temps would be doing with the new a/w ic and cooling sys combo. Since the lb7 doesn't capture intake temps (post ic) I decided to install the fuel temp sensor into the bottom of the new street intake...…….. drilled, taped, installed and use it as the intake temp instead (and be able to log with efilive). Extended the pig tail, along with the fps pig tail and ran with it. Wasn't sure how hot it would get, wasn't sure how high the sensor would read, didn't know if the ecm would freak out if it got to hot...……. or what is too hot??
Normal driving, in town and some freeway speeds intake temps stay from 120 to as low as mid 90's with good airflow (highway speeds). In traffic those temps will rise as the intake takes in heat from the heads and rest of the engine, but with the fan on it should keep it in check, still needs to be confirmed but so far so good.
Now racing...……… today was the first trip with the new combo. We made 5 passes in 3 hours, the last 2 were 20 minutes apart. The intake temps ranged from 115-138 during the run from staging to the end of the pass, that's no fan during the run just circulating water thru the cooling system. After the pass I would run the fan on the shut down, return road and in my pit, which this is my normal procedure anyways. I run one fan that now services both radiators, it works well. The temps rose to as high as 154 during the shut down and started dropping on the return road down to the 120's before I would turn the fan off.
The system is working really well, temps are happy, engine is happy and I'm capturing the data. Seems like a win win :-)
j
  #84
Old 12-08-2018, 08:31 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Those temps are great.
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #85
Old 12-09-2018, 07:17 AM
gassux gassux is offline
how much do you have invested so far? asking for a friend.
07 2500HD CC LBZ For Sale 92k 29,000neg
"Young man, I'm gonna twist off your head and spike it onto the floors of a nightmare you can't even imagine! I will dance with you inside the six-sided ring of fire, unless you move from this area, far and fast, NOW!"
Originally Posted by RPM Motorsports View Post
That would suck getting nailed for dyed fuel ..., "But officer it's the Koolaid, call McRat!!"
  #86
Old 12-10-2018, 08:19 AM
rfletes79's Avatar
I don’t know, I don’t keep track of that. And the combo has evolved so many times in the last decade, it would be next to impossible to account for everything.....
It wouldn’t be that difficult to figure out what it would cost to build it. We all know what these motor cost to build (it’s in my signature) even using mostly stock parts. In all reality I have more invested in the trans, od and rear end then the motor. It’s been that way for some time now. Strange rear end is about 4K. Od is 3500, and I have about 4K in the trans (including converter).
To build it ‘as is’ isn’t as bad as what I have ‘into it’.
j
  #87
Old 12-12-2018, 01:03 PM
rfletes79's Avatar
https://youtu.be/FzrJqEGEfoo
hopefully this works...….. one of our passes from this past weekend.
j
  #88
Old 12-16-2018, 11:47 AM
rfletes79's Avatar
Another weekend of testing, made the trip to Famoso yesterday. Track was on point, it took everything we threw at it. Got faster every pass, just ran out of time. Made some fueling, maf, batteries and bump adjustments during the week that all seemed to work out. Pretty sure this wraps up our 2018 season and we’re in a good spot going into 2019. Excited for next year!!
This was our best pass yesterday. 10.55
https://youtu.be/m9CJSYCwDU8
j
  #89
Old 02-14-2019, 10:03 PM
rfletes79's Avatar
Forgot to post our last outing. Was last month in January here locally. Was only 1/8 mile passes due to wind and cold but car worked great. Best 60 et and mph. Ran a best of 6.61@102 with a 1.435 60. Hoping to doing better next week Im Socal, running a 6.50 index class.
j
  #90
Old 02-14-2019, 10:09 PM
rfletes79's Avatar
Latest updates/changes. Added an anti roll bar and a hitch!! Time to put her to work. All done here locally at Dow Brothers RaceCars.
j
