  #76
Old 04-06-2019, 01:50 PM
chevyman chevyman is offline
FNG
Everyone says the strokers are only good for max effort racing or pulling. I really think it would be great for daily driving and towing with the bump in low end torque that is possible. I'm really thinking this is the route I'll end up going. I'm really interested to hear how it runs with new tunes and what you think of it.
  #77
Old 06-11-2019, 06:29 AM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
Haven't updated in a while..., Got new tunes from Mark at Danville and also a 3rd gear start TCM tune. Truck runs good but a little laggy in the lower rpms, converter is to tight so I have a Goerend "J" on order. Also did my first pull with it last weekend. Had a hard time getting turbos to light, but when they did 50-75ft out it through the belt and lost power steering and the 2nd CP3, still ended up 1st out 7 trucks, Heres a link to the video of pull.
https://youtu.be/pv83tw-5IBw
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
  #78
Old 06-11-2019, 07:00 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Did you check to see if you have a plastic or metal pulley on the tensioner? How old is your tensioner?
Current Rides:
-Built Motor, Tuned by Zach @ Starlite, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #79
Old 06-11-2019, 07:13 AM
duramaxzak's Avatar
Wanna be puller!
Plastic, I ordered a new steel one.
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
  #80
Old 06-11-2019, 08:30 AM
Bdsankey's Avatar
Gearhead
10-4, my truck (knock on wood) hasn't thrown a belt yet with the dual fueler and it ran some crazy RPM at DPC in Denver. It definitely hit the hard limiter a few times (5200rpm) and doesn't show any signs of wear on the belt.
If I recall correctly your dual fueler is an MPI kit correct? I know guys have seemed to have good luck with the new PPE routing (which I believe yours is routed that way currently).
Current Rides:
  #81
Old 06-11-2019, 03:53 PM
prostreeter600's Avatar
prostreeter600 prostreeter600 is offline
Street rodder
How long has it been since PPE started using a new routing ?
06 GMC Sierra RCSB Full built motor, carillos, 14/1 Arias W/total seal rings, 9100 AF, SCalTit retainers,SCalsprings,ported heads, SCal pushrods, 625 head studs, O-ringed block, keyed oil pump ,Billet Aluminum Lifters, Harland Sharp Aluminum roller rockers, studded rocker shafts, studded & girdled mains, socal balancer, socal flywheel, PPE Dual Fuelers with twin Fleece 10 mm CP3s , FASS Titanium 260 , 3" bridge, , TRIPLES----2---S369SXEs .88ARs over a Hybrid GTX 4202R--72mm/87mm 1.0 AR ,coilovers at 4 corners, 36" ladder bars, BD cooler, Exergy LBZ 250s ,FF Dynamics fans, PPE mans & ups , MA mounts & TC Brace ,NOS, Full Billet Trans, Suncoast 10531-3D , 3.42 Gears, BT lockup box. 16 x 12s & 16 x 10 Real Wheels with M & H 12/16s and 13/16s. TUNED by MARK@DANVILLE. Engine by Jason Walker San Marcus Tx. Best 60'---1.42 .Best 1/8---6.19@113.24 . Best 1/4 prior to 6.19 is --9.978@136.39
  #82
Old 06-11-2019, 05:20 PM
Bdsankey's Avatar
Gearhead
Good question, itís been awhile. Itís routed like a dual fueler with oil centrifuge kit. Iíll upload a pic tomorrow.
Current Rides:
