Old 07-13-2018, 07:19 PM
shotgunwilly1117 shotgunwilly1117 is offline
Gearhead
Default LLY Inconsistent fuel pressure
I have an 05 and have been chasing a ghost the past couple of months. At idle it would sometimes run rough with the fuel pressure jumping all around. Itís gotten worse the last week or so. I can now see my fuel pressure jumping around going down the road but I donít feel the rough running at speed. I have a lift pump installed if that makes a difference. Any ideas of where to start diagnosing? Picture/video of monitor to come
Old 07-13-2018, 07:27 PM
Gearhead
https://youtu.be/qeacuiAYoyM
Gearhead
https://youtu.be/yvFFNrxT9YE
Old 07-13-2018, 07:43 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
You have a sticky fuel pressure regulator. And it looks like your injectors are also on their way out....
2003 GMC CCSB LLY
Built by me, tuned by me.
Old 07-13-2018, 07:51 PM
Gearhead
Is the regulator repairable or just replace? Injectors have 260 on them so that wouldnít surprise me
Old 07-13-2018, 08:20 PM
TheBac's Avatar
TheBac TheBac is offline
Replace. Make sure its an actual GM/Bosch part. Dont buy a cheap Chinesium one.
Tom
Old 07-16-2018, 06:53 AM
Brent@LDS's Avatar
Brent@LDS Brent@LDS is offline
Looks like an FPR issue.
http://lincolndieselspecialties.com/...regulator.html
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-361-7700
Old 07-22-2018, 07:22 AM
bigedlittle's Avatar
bigedlittle bigedlittle is offline
FNG
I replaced the fpr on mine for the same issue. Completely resolved it.
Sent from my SM-G930R7 using Tapatalk
  #9
Old 07-23-2018, 02:22 PM
jcweller1 jcweller1 is offline
FNG
Default Erratic Idle and or rough Idle
I had a similar problem 05 LLY and replace the FPR.
stopped the erratic up and down idle but never fixed the rough idle. I have new Doc Sadler Twister Injectors and a new CP6 flow matched injector pump and Kory Willis tuner. Runs like a raped gorilla but has a rough idle just when you touch the accelerator with you toe. Can't figure it out.
  #10
Old 07-23-2018, 03:08 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Uh wut
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #11
Old 07-23-2018, 04:50 PM
AZlml's Avatar
AZlml AZlml is offline
Originally Posted by zakkb787 View Post
Uh wut
Cp6 is 2x better than cp3 obviously.
Bryan
11 CCSB 4x4
Full delete, EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
  #12
Old 07-23-2018, 05:59 PM
IOWA LLY's Avatar
Yes, its really me
Put some clothes back on that gorilla. Sounds like thatís definitely your problem.
2003 GMC CCSB LLY
  #13
Old 07-23-2018, 09:19 PM
Burn Down's Avatar
Lawerence Taylor “Don’t smoke crack”
Albert
04.5í CCSB ole blue, built trans, mpi twins
03í Reg Cab ZF 6
05í CCSB Millennium Falcon, built eng, built trans, mpi twins
