Go Back   Duramax Diesels Forum > Duramax/Diesel Technical > Duramax Hard Parts > LLY
Notices
Thread Tools Display Modes
Old 07-22-2018, 07:12 AM
bigedlittle's Avatar
bigedlittle bigedlittle is offline
FNG
Default LLY Got Hot!!!!!
I would like to give a little info before I ask a question of you guys. I have a 2005 lly that I bought new. It has 207k on it. I have pulled everything from a D3 Dozier to a 15000 lb. Loaded dump trailer on flat ground here in Ms. Never once have I gotten above the standard 200/200 with trans and engine temps.
I have moved from hauling work stuff to hauling a 6000 lb. Camper. Change of pace!!!
Just returned from a 5000 mile trip to south Dakota and Wyoming, that almost killed my truck.
Now for the question. I've been all over the forums and threads start out great and usually end up way off topic.
Other than a larger trans cooler ( hayden/ppe) amsoil bypass filter and upgraded turbo neck. What are my options to prevent over heat on my next trip?
Can a external oil cooler be used with the amsoil bypass system?
Sent from my SM-G930R7 using Tapatalk
Old 07-22-2018, 07:14 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
When's the last time you pulled out radiator and intercooler to clean them?
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
Old 07-22-2018, 07:23 AM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
And when was the last coolant drain and fill?
Joe
2008 CCLB LT2 DURAMAX LMM
13.39 @ 99.44 mph W/ 1.76 60’
456HP 925 TQ
2003 Regular Cab LB7
Old 07-22-2018, 07:24 AM
Burn Down's Avatar
^^^ This and what mods have you done to the truck?
Albert
04.5’ CCSB ole blue, built trans, mpi twins, 12.5X @ 108
99' Reg Cab, 1500 2wd, Turbo or Procharged 6.0, 4L80E build inprogress
05’ CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60’
84' Reg Cab SB, 415 BBC, 4-speed, needs a D-max zf6 swap
Old 07-22-2018, 07:45 AM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
I would start with cleaning the cooling stack and making sure your fan clutch in working. Maybe upgrading it to a Kennedy one https://www.kennedydiesel.com/catego...ubCategory=209
Other then that if you want togo big, engine oil cooler.
Old 07-22-2018, 08:31 AM
FNG
I have changed oil. Coolant and trans fluid. Regular service. At 150k I flushed and cleaned intercooler and radiator. Truck is stock other than cat removal.
Old 07-22-2018, 08:46 AM
2004LB7's Avatar
2004LB7 2004LB7 is online now
They're talking about actually removing the radiator and intercooler and washing the fins to clean it up.
Leaves, bugs and dirt clog it up reducing air flow and cooling
2008 Chevrolet 3500HD DRW LTZ
Old 07-22-2018, 08:50 AM
FNG
I have not done that. Currently at work so I can pull them both Tuesday. What solution would you suggest spraying them with before washing them down?
  #9
Old 07-22-2018, 09:12 AM
gmac32 gmac32 is offline
I just pressure wash everything carefully. I wash the backside first and then the front. Hold each piece up to light and see if you can look through it.
2011 denali gmc 5.5 lift, 35" tires, carillos, cut, coated lml pistons, hot cam 63.5 mm vgt over billet s480, fox shocks, profab manifolds and up pipes, intercooler pipes, 10mm cp3, ported heads, valve springs
  #10
Old 07-22-2018, 09:11 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
S100 motorcycle cleaner from a Harley dealeris what I use. Maybe a Coil cleaner from the hardware store would work fine. You don't want to use something like simple green that will corrode aluminum.
06 GMC 2500 CCSB SLT LBZ 4X4
  #11
Old 07-22-2018, 09:30 AM
2004LB7's Avatar
Personally if its bad I use oven cleaner with Sodium Hydroxide in it bit it is hard on aluminum so you don't want to soak it for more then a few minutes. Otherwise I just use dish soap and like mentioned above, wash from the backside first to push all of the junk out instead of deeper in
  #12
Old 07-22-2018, 09:51 AM
FNG
Thanks guys for the info. I have ordered an amsoil bypass filter system. Will it be ok to place an external oil cooler on the return side of the filters?
  #13
Old 07-22-2018, 09:56 AM
duramax on fire's Avatar
duramax on fire duramax on fire is offline
Did the fan ever lock in when it got hot? My lb7 would get hot with a clean stack until I changed the fan clutch. If it doesn't sound like a school bus fan when it's hot the clutch is bad.
  #14
Old 07-22-2018, 11:41 AM
FNG
It stayed locked in most of the time.
  #15
Old 07-22-2018, 10:44 AM
Chevy1925's Avatar
My suggestion:
Put a lbz mouth piece on the turbo (goes between turbo and intake tube)
Clean the cooling stack (make sure you separate the intercooler from the radiator and pressure wash both in both directions)
Put a new fan clutch on, preferably a Kennedy engineering one that will kick on 20* sooner
New thermostats.
Keep the dexcool and change/fill it back up
While the radiator is out, change the little coolant hose between the fan pulley and coolant y pipe (gets missed a lot and you don’t want that blowing)
Between all that, you should see a decent drop in coolant temp assuming you are on stock tuning. If not, we gotta look other issues
James
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
2002 2500HD CC/LB dmax/6sp alli "The Limo" SOLD - Gone but not forgotten
Tailgate Crew Member #4
