  #16
Old 04-07-2017, 05:30 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Thanks guys. I've read that thread, and I have a mityvac. I just don't have one that switches from vac to pressure
2003 GMC CCSB LLY
Built by me, tuned by me.
  #17
Old 04-07-2017, 08:20 PM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Originally Posted by 2004LB7 View Post
the Mighty vac thread posted a bit ago by bullfrogjohnson
http://www.duramaxdiesels.com/forum/...ad.php?t=36759
The problem with this is that the return lines are a pain to get to. I could tell you which side is leaking and have the valve cover half off till you even knew which side was leaking using that method.
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
  #18
Old 02-21-2019, 06:09 PM
Rmart30 Rmart30 is offline
FNG
Will this just show return line leaks, or would it also show injector body leaks?
