  #1
Old 05-15-2019, 01:01 AM
Rancelot211's Avatar
Rancelot211 Rancelot211 is offline
Boyd
Default Iso lbz alternator
Anyone have a good used alternator for an 06 lbz. Seems my voltage regulator is bad. Figured I'd look for a cheap one here before going to autozone or having a local shop rebuild it.
__________________
Travis Boyd
2007.5 lmm Ccsb: 628hp 1237 ftlbs.-sold
06 lbz ccsb sas. 72mm/s483. 10mm cp3. 60 overs studs custom fuel system and 37s. Ford super 60 with an arb air locker up front dodge 11.5 rearend ford nv273 transfercase. a Bunch of other goodies!
02 lb7 reg cab 4x4.
  #2
Old 05-15-2019, 03:40 AM
TheBac's Avatar
TheBac TheBac is offline
Default
Moved to Garage Sale.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #3
Old 05-15-2019, 05:49 AM
gmac32 gmac32 is offline
Default
I think i have one. I will look.
__________________
2011 denali gmc 5.5 lift, 35" tires, carillos, cut, coated lml pistons, hot cam 63.5 mm vgt over billet s480, fox shocks, profab manifolds and up pipes, intercooler pipes, 10mm cp3, ported heads, valve springs
  #4
Old 05-15-2019, 05:50 AM
Default
Where in ohio are you?
__________________
  #5
Old 05-15-2019, 12:21 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
Rockauto has brand new Remy units for around $135 last I checked.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #6
Old 05-17-2019, 11:09 AM
Boyd
Default
Im in tiffin,ohio 44883. Ill drive an hour or 2 depending on the price.
__________________
Travis Boyd
02 lb7 reg cab 4x4.
  #7
Old 05-17-2019, 11:11 AM
Boyd
Default
Thanks ferm. I was thinking about rebuilding mine. Its only charging at 13 volts. Figured id i could find a cheap used one id go that route until i can pull mine out and order a rebuild kit for it. Any way to tell which alternator i have? Not sure if an rpo code will tell me.
__________________
Travis Boyd
02 lb7 reg cab 4x4.
  #8
Old 05-17-2019, 02:05 PM
gmduramax's Avatar
gmduramax gmduramax is online now
Shits broke
Default
I have one out of my LMM I think if it didn’t get thrown away yet. Shipping might be expensive I’m in CA.
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #9
Old 05-18-2019, 12:17 AM
Boyd
Default Alternator
Send me a quote. Shipping would be to 44883 tiffin,ohio
__________________
Travis Boyd
02 lb7 reg cab 4x4.
  #10
Old 05-19-2019, 11:04 AM
LEGALLY INSANE
Default
LBZ uses an oddball DR44G, but it has a 4 pin regulator since the LBZ ECM is not setup to control the charging system. LMM is supposed to be a DR44 or a Bosch unit with a 2 pin regulator as the LMM ECM works in conjunction with the charging module to vary voltage output. You can also get an AD244 from an earlier truck to run on an LBZ.
__________________
  #11
Old 05-20-2019, 03:06 PM
Boyd
Default
Thanks ferm. It charges anywhere from 12.9-13.6 volts. Figured it should be more then that.
__________________
Travis Boyd
02 lb7 reg cab 4x4.
  #12
Old 05-20-2019, 03:15 PM
gmduramax's Avatar
Shits broke
Default
Quote:
Quote:
I didnít know they were different so I guess that wonít work. I know on my LMM itíll charge as low as 12.9/13 once the trucks been running a while. The LB7 we have stays around 13.8/14.2 and those are taken off of a volt meter not the gauge on the dash.
__________________
10.98@124mph
  #13
Old Yesterday, 09:06 PM
Boyd
Default
Gmac has one for 15$ and hes only an hour away so ill grab that. Thanks guys.
__________________
Travis Boyd
02 lb7 reg cab 4x4.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
