  #1
Old 05-14-2019, 12:49 PM
lawnboy01's Avatar
lawnboy01 lawnboy01 is offline
Default Lb7 filled block motor
Filled block Lb7 - lml block
Stand alone harness
Wagler solid iron heads
Callie’s ultra billet crank
Crower rods
Diamond pistons
S&s 400 injectors
Internal balance
Fluid dampener
S&s reverse 10mm pump
Exergy 12 mm in valley
Wagler oil filter delete
MA motor mounts
Remote mount turbo
Kodiak oil pan
So cal 9200 cam
Billet main caps
ARP bolts and studs inside
The bad
Two bad holes
$12000
Will part out if doesn’t sell
__________________
2019 High Country CC dually
2006 GMC Limited Prostock Diesel "Backwoods Evolution "
  #2
Old 05-14-2019, 02:37 PM
B1 596 B1 596 is offline
Dmax rods cost how much..
Default
Is the Callies crank Internally balanced ?
__________________
05 lly Dipper trans / Precision converter, Moonshine tuned, Ad II 165, And coming soon...TRIPLES !
  #3
Old 05-14-2019, 06:41 PM
lawnboy01's Avatar
Default
Quote:
Yes internal
__________________
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
