Old 11-21-2018, 07:38 PM
N2BRK N2BRK is offline
Default Finally ordered mine
it only took me how many years to finally make that turbo sock move from cart to completion? LOL. Looking forward to getting one!
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
Old 05-09-2019, 10:33 AM
And only 6 months to install it. Lmao. I put it in last night. Easy as pie. Can’t wait to put a few miles on!
08 LMM Crew 4x4
Exergy 12mm
Old 05-09-2019, 07:15 PM
Wow, I can actually feel a difference, and my EGT gauge notices one too. I'm surprised. I noticed that my turbo actually lights a hair faster. I have a tune that has a little lag just off the bottom, and I felt it cleaned up a bit and lit faster now. Very cool.
Any sense in trying to run a sock on the cold side pipe and/or hot side? I'd like to do up-pipes one day, but I cringe thinking about taking them off again! LOL.
08 LMM Crew 4x4
Exergy 12mm
Old 05-10-2019, 08:37 AM
Turbo Performance's Avatar
Turbo Performance Turbo Performance is offline
Sorry! I flat out didn't see your posts but I'm glad you're liking the blanket!
I wouldn't recommend blanketing the intake pipes. While it might be beneficial for a short amount of time, eventually they will get heat soaked and work against what you're trying to achieve in the first place.
You're better off keeping the heat at the source and letting the pipe bleed heat to ambient if it needs. IMO
Levi
turboperformanceproducts.com
208)251-9141
Turbo/Manifold/Hotpipe Blankets
Old 05-10-2019, 09:07 AM
great advice, thanks. Somewhere in the back of my mind, I remembered you making a set for the Elephant, but I didn't find any update as to effectiveness... should have been my first clue
08 LMM Crew 4x4
Exergy 12mm
Old 05-10-2019, 09:38 AM
I'm not sure that I've ever knowingly made a set of intake blankets. Not that I wouldn't. I just try to share my experiences so someone doesn't waste time/effort/money on something that might not work all that well.
Levi
208)251-9141
Old 05-10-2019, 10:41 AM
found it. 4th post down - 4 foot turbo sock. https://www.duramaxdiesels.com/forum...ad.php?t=70247
08 LMM Crew 4x4
Exergy 12mm
Old 05-15-2019, 07:10 AM
I stand corrected. Completely forgot about that one. Nice internet ninja skills.
Levi
208)251-9141
  #9
Old 05-15-2019, 07:27 AM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is online now
NOT IN OREGON
That was Mike though, weather it worked or not it made him happy so that's all that mattered.
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret sheep converter
supporting mods
  #10
Old 05-15-2019, 04:03 PM
That’s true! Remember the motor mounts making the handling better He was cool. We exchanged a lot of emails and texts
08 LMM Crew 4x4
Exergy 12mm
  #11
Old 05-16-2019, 05:59 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Thatís true! Remember the motor mounts making the handling better He was cool. We exchanged a lot of emails and texts
I could see that being true on the generation of truck Mike was working on. Those older square body frames are flimsy compared to what we have in our factory equipped duramax trucks.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #12
Old 05-16-2019, 08:58 AM
OregonDMAX's Avatar
NOT IN OREGON
No he had an 06-07 lbz he was just an oddball
Sean
02 CCSB
supporting mods
  #13
Old 05-16-2019, 09:00 AM
OregonDMAX's Avatar
NOT IN OREGON
He was a unique individual, I thought he was annoying until I met him in person then I realized yes a dually a cool dude, still weird though.
I still got some conveyor belt in my shop with his name on it that I got from work that he was going to use to make an air scoop for his trans cooler
Sean
02 CCSB
supporting mods
  #14
Old 05-16-2019, 09:04 AM
Columbus450's Avatar
Columbus450 Columbus450 is offline
And you didnít have to remove the turbo for the blanket?? Iíd be interested in one for my LBZ
Update
Never mind I just checked out the guys website looks like theyíre held in with ties
  #15
Old 05-16-2019, 03:32 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
I mss ole Mike, he was cool old dude...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
