Old 07-22-2019, 07:55 PM
wilsondiesel's Avatar
wilsondiesel wilsondiesel is offline
Default ZF6 Pullers out there?
I have a buddy with a ZF6 LLY, south bend dual comp clutch, 68mm charger, 10mm pump and 45% over injectors. He is running to aggressive of mud tire, and is having a hard time coming out of the hole smooth. Any advice on to switch to all terrains that he can blow off out of the hole? Or what gear to run and what rpm to leave at? Thanks!
2002 LB7 the fun truck
2018 L5P
DD-2001 VW Jetta TDI 5 speed
Old 07-23-2019, 06:15 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Mud tires, around here on our hard clay tracks, take 800+ to run them properly and spin out at the end of a run.
What gear and RPM is he leaving in now? Personally, I think an all terrain may be better for him but I'm nowhere near as experienced with manual trucks as I am with autos.
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, F1 Diesel 275% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend AR Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, "Budget" Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
Old 07-23-2019, 09:02 AM
He was trying 3rd 4 low and letting out of the clutch at 3200-3000 rpm. Yeah the zf Pulling game is new to me compared to auto.
2018 L5P
Old 07-23-2019, 09:04 AM
Bdsankey's Avatar
68mm vgt or S400?
K&D Service Inc
Current Rides:
Old 07-23-2019, 11:42 AM
Vgt on this truck
2018 L5P
Old 07-23-2019, 06:55 PM
dirty_max's Avatar
dirty_max dirty_max is offline
He's having trouble in 3rd? Oh boy. Come out of the hole way higher on rpm. I had mud terrains and pulled in 4th gear and i left the line closer to 4k rpms. And if it was a sticky track i would side step the pedal and send prayer up to the big man
2004 chevy lly with a handshaker
Originally Posted by coker6303
My trucks not a whore...she doesn't lift her skirt for just anyone!
But she is a prostitute...she will do anything for money
Old 07-23-2019, 08:13 PM
I tell him to leave higher as Id like to see him run 4th but can only lead a horse to water, cant force it to drink lol
2018 L5P
Old 07-24-2019, 07:37 PM
dirty_max's Avatar
He has to be tached out all the way down the track. I had a track once that i could absolutely not get off the line in 4th and had to run in third and it was terrible. That was the hottest i had ever seen that truck. The engine was ticking, my coolant temp was still climbing while i was driving away from the sled, pyro was burried for quite a while. But it was fun
  #9
Old 07-25-2019, 04:46 AM
Bdsankey's Avatar
After looking at the rpm/speed calculator I can see why. 3rd gear is only 2.1:1 ratio whereas 4th is 1.31:1. Every auto duramax guy until up until 800-1000hp runs 3rd gear in an Allison which is 1.41:1 so he should be able to run it in 4th.
K&D Service Inc
Current Rides:
  #10
Old 07-25-2019, 07:11 AM
Chevy1925's Avatar
but you are not accounting for converter torque coupling that basically reduces 4th gear ratio by 2 or 3:1 UNTIL you hit lock up. that helps get you out of the gate with enough speed before hitting lock up and carrying it through.
you slip a clutch like this and it wont last long
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
  #11
Old 07-25-2019, 07:20 AM
Bdsankey's Avatar
All depends on what evil you want to play with. RPM the thing out for all its got or slip the clutch out the hole. Every stick sled puller realizes the clutch is a wear item and knows that it doesn't have infinite life.
K&D Service Inc
Current Rides:
  #12
Old 07-25-2019, 07:30 AM
Chevy1925's Avatar
youre missing the point of my post....
James
  #13
Old 07-25-2019, 10:31 AM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
This is what we did with an s475 and 100%s running 35 mud tires
03 reg cab. Low and slow
07 crew long classic- stolen
  #14
Old 07-27-2019, 04:25 PM
dirty_max's Avatar
sounds good on paper but just like the other guy said, getting out of the hole is an entirely different story. yes we realize the clutch is a wear item but either way you come off the line, it rough on things. moral of the story is, auto trans is better.
  #15
Old 07-29-2019, 08:08 PM
Well guys he made a lot smoother pass this weekend! He bounced just a bit out of the hole but came out of it very quickly, he ran third but could tell it was tached out going down the truck. Thanks everyone for the advice. Now to play with fire on my LB7 and get the other 10mm pump put on for the rest of the season!
2018 L5P
