  #46
Old 03-11-2019, 09:52 AM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
Originally Posted by Rancelot211 View Post
Have a phone number for levi?
https://turbo-performance-products.myshopify.com
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
  #47
Old 03-11-2019, 04:37 PM
Rancelot211's Avatar
Rancelot211 Rancelot211 is offline
Boyd
Thanks zak.
2007.5 lmm Ccsb: 628hp 1237 ftlbs.
06 lbz ccsb sas. 72mm/s483. 10mm cp3. 60 overs and a Bunch of other goodies!
02 lb7 reg cab 4x4. Race truck in progress!
  #48
Old 03-19-2019, 05:54 PM
duramaxzak's Avatar
Wanna be puller!
I found these 90 degree quick connect heater hose fitting that work with these heater core outlets. The factory straight fittings point almost straight into the exhaust crossover pipe.
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
  #49
Old 03-19-2019, 06:00 PM
duramaxzak's Avatar
Wanna be puller!
Picture of the re routed heater core lines. I still need to shorten the oil drain line.
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
  #50
Old 03-19-2019, 06:14 PM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Those are handy, where did you find them?
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #51
Old 03-19-2019, 06:24 PM
duramaxzak's Avatar
Wanna be puller!
Gates makes them.
Pn. 28505 fits 3/4" heater hose
Pn. 28504 fits 5/8" heater hose
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
  #52
Old 03-20-2019, 06:42 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Good find Zak!
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #53
Old 03-20-2019, 08:15 AM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Attachment 49165
One line from the heater core goes into the bottom rad hose, I see that one. Where do you have the top line going? It should go to the top of the thermostat housing. Am I missing something???
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, sdp y bridge, big dipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #54
Old 03-20-2019, 08:22 AM
duramaxzak's Avatar
Wanna be puller!
I tapped the coolant crossover and running the 12an line over the top of the alternator and down.
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
  #55
Old 03-20-2019, 08:24 AM
duramaxzak's Avatar
Wanna be puller!
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
  #56
Old 03-20-2019, 03:33 PM
Ah ok, by chance can you post a list of everything you used my trucks in pieces right now and I got rid of the line that runs up behind the motor so I'm looking to relocate mine
  #57
Old 03-21-2019, 06:36 PM
duramaxzak's Avatar
Wanna be puller!
- 10ft of 12AN hose
- 2 Gates 28505 90 deg quick connect fittings
- 1 90 deg 12AN female hose end
- 3 straight 12AN female hose ends
- 1 90 deg 12AN male union
- 1 10AN to 12AN straight male union
- 1 10AN male straight push lock
- 1 12AN to 1/2 NPT standoff
Or you could use the Gates 28504 fittings and 5/8's heater hose and barb fittings.
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
  #58
Old 03-21-2019, 08:01 PM
hntngkd's Avatar
hntngkd hntngkd is offline
Attachment 49164
I had used the same fittings when I first installed the compounds on my truck and I had an issue with one blowing off constantly during high rpm pulls. I tried a ton of different ones and they all did the same thing. I went back to a straight one and it solved all my problems. Just something to keep an eye on. They felt like they snapped on fine but more than a handful of times I had one of them blow off. Im not sure what was causing it, if it was just the sharp 90 and there is too much coolant flow through there or what.
2006 "LLY" ECLB DRW, DEAD 5/3/2015.... Alive again..... 11/30/16
Fingers cast 15.5:1, R&R rods, Callies billet crank internally balanced, Wagler AF stage 2 Cam, Main Girdle, Billet Mains, Fire ringed block,
Wagler Pushrods, Valve Springs, Ported LBZ heads
SBDDD 3600lb sintered iron
HSP Compounds SXE-371/75/.91 S485/96/1.32 V2 by Forced Inductions, Profab castflow manifolds, Turbosmart Hyper-gate HP45, Turbosmart Race port BOV and controller, Mishimoto Intercooler
Exergy 250% injectors, Dual Fuelers, Fuelab 200
Danville tuning
FF Dynamic Fans
ARB air locker
2017 Cruze LT diesel LH7 stock
  #59
Old 03-22-2019, 06:39 AM
duramaxzak's Avatar
Wanna be puller!
Good to know...
I'm a machinist by trade, and have been thinking about making some billet ones that will accept 12AN fittings.
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
