Old 09-11-2019, 04:49 AM
dzimbric's Avatar
dzimbric dzimbric is offline
Gearhead
Default Trailer Brake & Parking assist fault
I keep getting a Trailer Brake Service fault, intermittently the fault clears and the brakes work. It’s really annoying when towing weight. I have replaced the brake control relay and the tail light circuit board and cleaned the connectors.
Is there another connector between the controller on the dash and the brake relay.
It happens with all of my trailers and even shows when no trailer is connected. I also have had the “Service Park Assist” fault for awhile but just ignore because I am normally pulling a trailer.
Any advice is appreciated.
2008 K2500HD CC/SB
7-9 inch Cognito Lift, Cold Air Intake. 4 inch exhaust, dsp5 tune by Diesel Addiction (Thanks Dustin), 35" Michelin Defenders on 20 Inch Ultra Spline Rims
'56 C6500 w/tilt
Old 09-11-2019, 07:26 AM
Chevy1925's Avatar
are you running a lift pump?
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
Old 09-11-2019, 08:37 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Behind the rear bumper is another connector. Mine was full of dirt and junk
2008 Chevrolet 3500HD DRW LTZ
Old 09-11-2019, 09:08 AM
TheBac's Avatar
TheBac TheBac is offline
Moved to Towing Section.
Tom
"BBT" -- 2003 GMC CC/SB 4x4 [email protected]
Old 09-11-2019, 11:55 AM
Ron Nielson Ron Nielson is offline
When you say you are getting a 'fault', are you referring to a message on the DIC? Or a check engine light that has a DTC associated with it? or ?? And this is for your 2008 truck in your signature?
Ron Nielson
2008 Chevy Silverado LT, SRW, Crew Cab, LB, LMM/Allison, Rear lowered 2": otherwise, fully stock at this point. Edge Insight CTS
Old 09-11-2019, 05:02 PM
dzimbric's Avatar
Gearhead
It is for the vehicle in my sig line. I am getting “Service Trailer Brakes’ message on the DIC. I get it with and without the trailer being connected. I replaced the brake light circuit board located behind the bumper and the brake relay located next to the fuel tank on the frame. It may be a loose connection because it was coming back in today with no trailer connected when I would hit a bump.
Suggestions?
2008 K2500HD CC/SB
'56 C6500 w/tilt
Old 09-11-2019, 05:05 PM
dzimbric's Avatar
Gearhead
I chaged it. No success.
2008 K2500HD CC/SB
'56 C6500 w/tilt
dzimbric's Avatar
Gearhead
No
2008 K2500HD CC/SB
'56 C6500 w/tilt
  #9
Old 09-15-2019, 02:36 PM
dzimbric's Avatar
Gearhead
Does anyone know what the module located next to the trailer brake relay does? It is mounted on the frame behind the fuel tank and has a weird plug that I can’t get apart. Also how do you get the plug off?
2008 K2500HD CC/SB
'56 C6500 w/tilt
  #10
Old 09-16-2019, 07:16 AM
JoshH's Avatar
JoshH JoshH is offline
That is the trailer brake control module. I just changed it on my dad's 08 dually because he was having intermittent service trailer brake messages, and diagnostics indicated that it was the problem. The new one is still giving those messages though... I remember the plug being a pain, but I don't remember exactly how it unlatched.
06 Silverado 4x4 CC/SB
  #11
Old 09-16-2019, 09:19 AM
A new trailer brake control module, which mounts right next to the trailer brake relay, must be programmed. A quick trip to the dealer, or independent garage, is in order. If the module was your problem, you may have a working, error free trailer braking system. If the problem lies elsewhere, you may still have problems.
Ron Nielson
