  #1
Old 05-01-2015, 07:25 AM
1brokekid's Avatar
1brokekid 1brokekid is offline
Gearhead
Default Things to do while the bed is off?
I'll have the bed off of the truck in a few weeks to repair some body damage, and I'm wondering what all I should do that's fairly cheap while it's off.
I've honestly thought about taking the tank out and cleaning it, as my fuel filter is absolutely filthy every time I change it every 5k miles. Is this worth doing? Any other fuel tank modifications I should do to it while the beds off? Any other problems or upgrades that should be done with the bed off? And does anyone have any info on cleaning a tank out?
__________________
Korbin
2006 Silver Birch CCSB 4x4 LBZ with 260k on the clock
3" drop shackles and overload removed, front decranked
20x10 eagle alloy with 275/55r20 sumitomo tires
4" MBRP straight exhaust, AFE intake tube/filter, PCV reroute
  #2
Old 05-01-2015, 08:01 AM
schulte schulte is offline
Default
Put a sump in the tank and while you're doing it, wash it out with paint thinner or kerosene and compressed air.
__________________
2004 CCSB LLY
  #3
Old 05-01-2015, 08:19 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
No need to clean tank.
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.32 @ 150
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
  #4
Old 05-01-2015, 08:49 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
pop the sender out and look at the fingers on the rheostat for your fuel level float. if they are worn out, the curved up ends may have broke off and soon your fuel gauge will be reading incorrectly. its not common from what ive seen but since you have the bed off, may as well check.
probably wouldnt hurt to clean the rust off the frame if there is any and recoat it.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #5
Old 05-01-2015, 10:47 AM
ty_LBZ's Avatar
ty_LBZ ty_LBZ is offline
Camaro killa
Default
Do a smokey burnout
__________________
LBZ CCSB 4x4. deleted. re-routed. shimmed. EFI by Kory 4" MBRP downpipe-back w/Corsa. Alligator trans cooler hoses. 3" Pro-Fab downpipe. Transgo Jr. Banks ram air intake. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. AirDog 150. Nicktane CAT filter adapter. SoCal 3388AF. ProFab charge pipe & Y-bridge. Mahle +0.020 pistons. Keyed cam & crank. ARP head studs, main studs, flywheel. Rotating assembly balanced. Merchant Auto motor mounts.
10/30/14- cracked piston
03/14/15-Back from the dead
  #6
Old 05-01-2015, 11:03 AM
chevyburnout1's Avatar
chevyburnout1 chevyburnout1 is offline
Fixing it till it breaks
Default
Quote:
Originally Posted by ty_LBZ View Post
Do a smokey burnout
Always fun having to explain why there is melted rubber on your back window
__________________
Dustin
'03 Silverado LB7
GT3788/CT6x88mm compounds _ 60's _ duals _ fingers _ 6480af
'77 K-10
52"/56" front/rear leaf springs and rear shackle flip: 8" lift total _ D60/14blt 4:56s _ 40" Swamper IROK's _ 383 w/nitrous _ SM465 _ 208tcase
'97 Cadillac Deville
Morimoto Mini 5000k projector headlight conversion _ 500watts in the trunk _ 20's _ Flowmasters _ Tuned ECM _ Rear mount turbo in the works....
  #7
Old 05-01-2015, 02:57 PM
BLACKMAX1's Avatar
BLACKMAX1 BLACKMAX1 is offline
WAY2EVL
Default
Clean, remove corrosion and re paint the frame.
__________________
07 LMM
Tuned by Danville Performance
Danville 72VGT
Exergy 45's
PPE dual fueler
AirDog 150
Built Trans, SC1058 converter
HSP Diesel manifolds/up pipes
HSP Diesel intercooler tubes/bridge
Mishimoto intercooler
Kryptonite/Rare parts front end
  #8
Old 05-01-2015, 03:15 PM
doug9940's Avatar
doug9940 doug9940 is offline
Ca LLY
Default
Good time to install a lift pump and sump.
__________________
2005 Sierra CCSB 2-WD
Mike L stage IV w/Precision ML convertor & Mike L trans cooler, Suncoast 6speed conversion
S&B Filter & Intake, AFE Bladerunner mouth piece (extrude honed) Garrett GT4094VA (w/Danville billet compressor wheel, extrude honed compressor housing & exhaust housing, jet hot coated exhaust housing), Banks Technicooler w/ 3" tubes, Wherli Fabrication custom 3" LBZ Y-Bridge, LBZ manifolds, RDL Pro-Flo Log style headers and up-pipes (jet hot coated and wrapped), Diamond Eye Down Pipe (jet hot coated and wrapped), 4" turbo back exhaust, EGR deleted, PCV rerouted
PPE Billet Fuel Pick-up, Airdog I 150 lift pump, Wicked Diesels stage III CP3, PPE race valve, PPE ported rail fittings, Exergy 60% over injectors
So Cal Diesel Stage 1 heads, So Cal #3388 camshaft, Carillo Rods, So Cal .020 over cast pistons, So Cal billet flywheel, ATI Damper, ARP head studs, main studs & flywheel bolts, Merchant H2O pump & Motor Mounts
EFI Live (tuned by Tony @ Ridge Runner Diesel....Moonshine)
677 HP 1032 TQ
  #9
Old 05-01-2015, 03:17 PM
Lparrill's Avatar
Lparrill Lparrill is offline
Iím Done
Default
Do a smokey burnout
My dad did that once and ended up throwing a rock into the back window and shattering it
__________________
Levi
SOLD ó 04 GMC CCSB LLY l Mahle Pistons with reliefs l Carillos l ARP Studs l Socal Stg 2 Heads l Suncoast Trans with Billet Shafts l Danville 72vgt l Double Bat S483 l HSP Piping l 60% overs l II 85% over + LBZ CP3 l FASS 220 l DRP Sump l BT Lockup Box l Fabtech "Traction"/Axle wrap Bars l Mishimoto Intercooler l Zex Nitrous
Tuning by Wade at Diesel Day Dreams
  #10
Old 05-01-2015, 04:33 PM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
Default
Back half it
__________________
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
  #11
Old 05-01-2015, 05:47 PM
ALLY Fox's Avatar
ALLY Fox ALLY Fox is offline
Old Man Truck
Default
Quote:
Yep, perfect time. Also, check all your fuel lines for leaks or cracks. Might be a good time to replace them with something better. Check you wiring and clean the connector contacts.
__________________
Basic old man '04.5 Sierra SLT long CC tow rig, EFI Live by Rob, trans by Mike L, Magnaflow DP, Airdog II 165, Ride Rites, LBZ MP, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W GN & Companion, Prodigy P3 and some other stuff but I can't remember what it is...
  #12
Old 05-01-2015, 06:57 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Replace that rear brake line!!!!
X2 to what James said about the fuel sender.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"Kleshay" -- 2000 C5 Corvette -- the toy
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #13
Old 05-01-2015, 07:28 PM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Default
x3 Frame paint if necessary
__________________
-Cody-
Instagram
@codydavemiller
@mfsdiesel
2001 LB7 CC/SB 4x4
S&B, 4"Silverline, AD150, 10mm Fleece 750, 65% SAC S&S Inj. Danville Tuning, Coming soon- Limitless Built Trans. & 369sxe
2007 LBZ EC S/B 4x4 SLT
4" MBRP SS
S&B Intake, Ridgerunner Moonshine Tuning
  #14
Old 05-12-2015, 07:11 AM
1brokekid's Avatar
Gearhead
Default
The frames already been painted, but I'm sure there are spots that I missed or need recoating, so I'll take care if that.
Someone mentioned a brake line? Which one is known to need replacing?
I planned on a lift pump anyway, so I guess I should do that while the beds off. Going to run Kennedy diesels single pump for cost sake. Thanks guys!
__________________
Korbin
  #15
Old 05-12-2015, 08:15 AM
wrcknkrw's Avatar
wrcknkrw wrcknkrw is offline
Default
Great time to cut off the spare tire mount and cross member for weight savings.
__________________
04 LLY sc lb 4x4 twins,trans,efi live,fass 150,edge insight,5" strait pipe
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
