Old 07-17-2015, 03:52 PM
JoshH's Avatar
JoshH JoshH is offline
Default How long has it been since you've seen anything like this?
The price of diesel is really cheap, but look at how much cheaper it is than gas. I don't know how long it's been since I've seen that.
06 Silverado 4x4 CC/SB
Old 07-17-2015, 03:54 PM
S Phinney's Avatar
S Phinney S Phinney is offline
Nothing like that here in Florida. Lucky you!
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
Old 07-17-2015, 03:56 PM
JoshH's Avatar
It isn't what I usually see for sure. This was at a big station that just opened up. I think they're trying to build up some traffic.
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
I think diesel got down below $2 for a week here a while back. But gas was cheaper.
03 reg cab. Low and slow
07 crew long classic- stolen
Old 07-17-2015, 04:04 PM
Nathan.'s Avatar
Nathan. Nathan. is offline
In Kansas City its still $2.50
2005 Sierra CC LLY
2006 Jetta TDI BRM
2014 Harley Davidson Street Glide Special
Old 07-17-2015, 04:08 PM
doug9940's Avatar
doug9940 doug9940 is offline
Ca LLY
This past January I saw regular at $2.17. Didn't stay there long though.
2005 Sierra CCSB 2-WD
Mike L stage IV w/Precision ML convertor & Mike L trans cooler, Suncoast 6speed conversion
S&B Filter & Intake, AFE Bladerunner mouth piece (extrude honed) Garrett GT4094VA (w/Danville billet compressor wheel, extrude honed compressor housing & exhaust housing, jet hot coated exhaust housing), Banks Technicooler w/ 3" tubes, Wherli Fabrication custom 3" LBZ Y-Bridge, LBZ manifolds, RDL Pro-Flo Log style headers and up-pipes (jet hot coated and wrapped), Diamond Eye Down Pipe (jet hot coated and wrapped), 4" turbo back exhaust, EGR deleted, PCV rerouted
PPE Billet Fuel Pick-up, Airdog I 150 lift pump, Wicked Diesels stage III CP3, PPE race valve, PPE ported rail fittings, Exergy 60% over injectors
So Cal Diesel Stage 1 heads, So Cal #3388 camshaft, Carillo Rods, So Cal .020 over cast pistons, So Cal billet flywheel, ATI Damper, ARP head studs, main studs & flywheel bolts, Merchant H2O pump & Motor Mounts
EFI Live (tuned by Tony @ Ridge Runner Diesel....Moonshine)
677 HP 1032 TQ
Old 07-17-2015, 04:16 PM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
It’s only temporary!
That sure beats the heck outta the 3.29 ive been paying!
2010 Silverado 1500 LTZ
Sheer Silver Metallic • Every option except Nav • K&N Intake • Stock and staying that way!
06 Chevy LBZ
Olympic White • Built Motor/Trans • Bullseye s375 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance
11.76@115.12 SOLD
08 BMW 528xi
Alpine White • Brown Dakota Leather • Premium/Cold/Smoker Pkg • LED AEs • MTec D1S • 50% tint
Old 07-17-2015, 04:36 PM
Burn Down's Avatar
3.41 in the AK... I have never seen fuel cheaper than gas in 12 years up here... It's been probably 25 ish years since it was that way in Idaho.
04.5’ CCSB ole blue, built trans, mpi twins
03’ Reg Cab ZF 6
05’ CCSB ole crappy, built eng, built trans, mpi twins
  #9
Old 07-17-2015, 04:38 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
$2.569 is the cheapest I have seen in weeks, most are around $3 a gallon.
  #10
Old 07-17-2015, 04:56 PM
Minnesota DMAX's Avatar
Minnesota DMAX Minnesota DMAX is offline
Gearhead
2.59 in southern MN. Nice seeing it cheaper than the premium unleaded.
02 CCSB efi live,head studs, S&B intake, 4" straight pipe to 5"
  #11
Old 07-17-2015, 05:15 PM
RPM Motorsports's Avatar
smokinum
$2.89 here for a few weeks now
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #12
Old 07-17-2015, 05:25 PM
DetailsUnlimited's Avatar
DetailsUnlimited DetailsUnlimited is offline
At Kroger In Little Rock, Ar
Don't know why it's sideways?
Gaylon(Tark)Tarkington
Trucks Name: Consistantly Inconsistant!
06 LBZ CCSB
Built motor
Team Hole in the Piston "RIP" 10/21/11
2011 NHRDA Ennis, Tx Sportsmen Champion
2011 NHRDA Sportsmen World Champion
2014 TS Performance 12.0 Index
New ride - 07 3500 Duramax Van
  #13
Old 07-17-2015, 05:26 PM
DBUSHLB7's Avatar
DBUSHLB7 DBUSHLB7 is offline
Team DMAX
2.36 I was paying in Albuquerque before I left on vacation for Minnesota. It's 2.55-2.65 here in Northern MN
  #14
Old 07-17-2015, 05:52 PM
superswamper003's Avatar
superswamper003 superswamper003 is offline
diesel is 2.55 at the local safeway gas station.. I dont remember how cheap it got down to several months ago though
Hendrik
2004 LB7-sold
05 lly cc/sb 4wd
pcv reroute, lbz mp, egr block plate, 5" magnaflow, G2 tie rods, ssdieseltuning efi, cts2, SDP built trans, pump rub fix, FPRV shim
270k miles
  #15
Old 07-17-2015, 06:27 PM
Burn Down's Avatar
Holy Santa Clause Sh*t! I would be stock piling/hoarding fuel at that price
03’ Reg Cab ZF 6
HTML code is On
