  #16
Old 12-08-2017, 06:38 AM
LCAC_Man LCAC_Man is offline
Gearhead
Default
Posting in in mPA is why everyone missed it...I didn't bother to convert it to psi until just now, yes, 1500psi is considered the proper starting pressure, less is usually a sign of worn/bypassing injectors but of course a leaking hard line give the same symptom...be thankful you have an LBZ now where you can actually see/get to those lines...had you still had the LB7 you'd have 8hrs worth of disassebly to get there and probably would have a crankcase full of fuel.
Glad you got it solved.
__________________
Len Barron
2000 Express 155"wb Passenger Hightop
  #17
Old 12-08-2017, 06:11 PM
Bob H Bob H is offline
Jet pilot wanna-be trainer
Default
Great note from another thread - wanted to put it here as well.
There is no "min pressure" the ECM needs to see before firing off the injectors. Rather, the internal design/springs/check valves/etc.. of the injector won't enable actual fuel to come out until it sees that ~14-1500 psi of pressure. ECM is asking it to fire, but nothing will happen until enough pressure to overcome the internal parts of the injector.
__________________
'03 CCSB GMC 2500HD 4x4 w/LBZ swap. Lowered 6", work in progress!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
