Old 02-12-2018, 12:24 PM
cdbright's Avatar
cdbright cdbright is offline
JUST RENT IT
Default LML white smoke
My 2015 LML is still stock as it has 34,XXX miles, i am about to go w a switch and 5 tunes and exhaust and what not but today i noticed i cloud of white smoke after getting on it on to the FWY. Tip is clean and i have not noticed it untill now (have had truck for about 3,XXX miles. I did finally have to add DPF fluid and used the only brand that MAVERICK carries here in SLC as i assume most of town uses this.
Have you seen white smoke from the fluid if it happens to be in a re-gen at the same time?
2016 GMC Denali 2500 4x4 CC/SB LML- 6" Rough Country lift w 20" XDs, EFI, Deleted , 5" straight, 3" DP, S&B
2015 GMC Denali 2500 4X4 CC/SB LML - (STOLEN)
2009 Chev 2500 LMM (TRADED) EFI, all deleted, rode just as hard as her !!!, stayed together
2008 GMC 2500 LMM (SOLD)
EFI,all deleted,rode hard,stayed together
Old 02-12-2018, 12:25 PM
cdbright's Avatar
JUST RENT IT
it seems it will dump more if i drive it real easy for a while and let it load up , injector over fueling?
Old 02-12-2018, 01:09 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Feel any loss in power? Notice more regens then usual? Can you look at balance rates?
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
Old 02-12-2018, 03:03 PM
cdbright's Avatar
JUST RENT IT
seems to be the same stock dog she always was. I just have the OBD II code ready and clearer, dont think it will give me rates. Could it be unburden DPF fluid?
Old 02-12-2018, 03:58 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
9th injector may be stuck on. Just had a 2015 Denali do it to us and it torched the cat into pieces. All covered under warranty.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Old 02-12-2018, 04:43 PM
cdbright's Avatar
JUST RENT IT
if so the DP fluid tank should run dry quick right?
Old 02-12-2018, 04:49 PM
ikeG's Avatar
Oughta Know Better
9th injector sprays fuel in the downpipe for regeneration
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Old 02-12-2018, 04:56 PM
Hoser Hoser is offline
I regularly see huge plumes of white smoke when I’m in regen and getting on it, sometimes it will be so dens it will completely block my view of all the vehicles behind me. The DEF and 9th injector have nothing to do with each other, other than the fact they are both part of the emissions system.
  #9
Old 02-12-2018, 05:10 PM
cdbright's Avatar
JUST RENT IT
how/where does the DEF get shot into the mix?
  #10
Old 02-12-2018, 05:23 PM
Columbus450's Avatar
Columbus450 Columbus450 is offline
The ninth injector injects diesel into the exh pipe to bring the exhaust gases up to a higher temperature, The DEF dosing injector will not dose until a regen process takes place So it can reduce nox Emissions it's usually found near the SCR and DPF filters
Sounds like you're having a over fueling issue take it back to the dealer it's under warranty
  #11
Old 02-12-2018, 06:05 PM
T2CH's Avatar
T2CH T2CH is offline
<<<Me...Not My Wife...
I get the white smoke when I get on my 16 toward the end of a regen. My '11 did it as well past 100k.
Mine isn't road blocking though, just a good haze. You might want to have it checked at the dealer if its that bad.
2016 LML CC SB, LTZ, Cognito Arms, 305-55/20 on stock wheels, Flow Pro DP Back, Fass 165, Deviant Sump, PCV Re-route, HID Projector Swap by Longshot Lighting,
Sold: 2011 GMC Duramax, CC
Sold:'06 GMC Duramax, CC, SB, SLT 4SA, Chrome H2's, 285 BFG's, Downpipe back MBRP, Autometer guages, AD II, BigDipper trans, Tuning by IdahoRob
  #12
Old 02-12-2018, 06:43 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
You have a cracked DPF...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
  #13
Old 02-13-2018, 10:01 AM
cdbright's Avatar
JUST RENT IT
it only did it bad once, then i got it to do it a little more one the freeway and now it is all clear , seems it was right at the end of the re-gen.
  #14
Old 02-13-2018, 10:03 AM
This is incorrect. The DEF is always being injected and used while the truck is running, as long as itís not frozen. 9th injector only injects fuel during a regen to heat exhaust and to burn off accumulated mass in the DPF.
  #15
Old 02-13-2018, 10:04 AM
I have had my truck at the dealer numerous times and have mentioned my clouds of white smoke, they say it’s normal. . . . .
