  #1
Old 05-12-2018, 10:54 AM
kubitza123's Avatar
kubitza123 kubitza123 is offline
Default 2011 LML 160mpa fuel pressure at idle?
My cousin is working on a lml that they fully rebuilt at his machine shop and installed. They also installed a new fuel pump . The truck started out without enough pressure and now after replacing the pump and regulator it now has way to much. Are the new regulators on these models prone to being bad? He said they are dirt cheap compared to the previous models .
Any ideas guys?
  #2
Old 05-12-2018, 11:21 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Check the wiring to the regulator and pressure sensor. If the regulator is unplugged or sont getting power it defaults to the full open position. If the pressure sensor is unplugged or has a broken wire, etc the ecu will read max pressure
Does it knock or run like it actually is running at 160 mpa or does it sound normal?
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
2006 BRM Jetta TDI. Injectors, turbo, Malone custom tuning on ecm and tcm
  #3
Old 05-12-2018, 12:46 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
Check Lift pump pressure
__________________
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #4
Old 05-12-2018, 02:25 PM
kubitza123's Avatar
Default
He’s checked all that , lift pump new as well. They have had a scope on it etc no electrical issue they can find . They are pretty positive mechanical prob of some sort. Yes it has fuel knock. Can crank the truck runs fine 5-10 seconds and then defaults to 160mpa.
  #5
Old 05-12-2018, 03:33 PM
02greysixer's Avatar
02greysixer 02greysixer is offline
Default
Make sure they don't have the plug for the fuel pressure regulator on the pump switched with the fuel temperature plug. Seen it before, usually presents as a no start though.
Sent from my SM-G930P using Tapatalk
__________________
2010 LMM CCSB LT
4" Flo-Pro
FASS 150
Beans Sump
Leveled w/ drop shackles
RidgeRunner Tunes
More to come
Rip zf6 swapped lly
  #6
Old 05-12-2018, 06:04 PM
kubitza123's Avatar
Default
Ok I’ll ask them, he builds these ,6.4’s, 6.0 etc every week so he prob has them right but first time for everything. He’s ready to beat the fenders off this one lol.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
