  #1
Old 08-15-2018, 05:07 AM
Redneckgt Redneckgt is offline
FNG
Default Injector return lines
What causes them to pop? Since replacing injectors I've had problems with my left bank. They're getting brittle, I've replaced them with cheapys to the expensive and still they crack and leak.
Any ideas?
  #2
Old 08-15-2018, 06:59 AM
Brent@LDS's Avatar
Brent@LDS Brent@LDS is offline
Default
You have bought the Brand New Bosch return lines and still having issues?
__________________
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-361-7700
  #3
Old 08-15-2018, 09:20 AM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is online now
NOT IN OREGON
Default
Are you overtorquing the return line bolts, they are turqued in in/lbs not ft/lbs
I think it's 10 in/lbs if I'm not mistaken
__________________
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
Exergy Sportsman, 4/6 drop, LML 20's/420's
supporting mods
  #4
Old 08-15-2018, 11:36 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
Return lines dont have bolts.
Try quality lines
__________________
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #5
Old 08-15-2018, 12:09 PM
FNG
Default
Quote:
Have not found Bosch lines. Have tried products from doorman, sinister, injectors direct etc.
  #6
Old 08-15-2018, 01:20 PM
OregonDMAX's Avatar
NOT IN OREGON
Default
Quote:
Try quality lines
Shouldn't have assumed, I didn't see it said lbz on the title my bad
__________________
Sean
02 CCSB
supporting mods
  #7
Old 08-15-2018, 02:08 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
Merchant lines are Bosch iirc
Sent from my XT1585 using Tapatalk
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #8
Old 08-15-2018, 08:49 PM
PureHybrid's Avatar
PureHybrid PureHybrid is online now
Isuzu Shakes IT
Default
I know you said they're cracked, but also said they pop? Do you have a clog somewhere in the return system? That will make them blow off.
I'm running cheap plastic Tee's on the injectors with the good braided Gates hose, the cheap hose was cracking like you stated before. Haven't had an issue once putting good hose on.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
8.17@84mph 1/8mi
Jesse
  #9
Old 08-15-2018, 10:03 PM
Brent@LDS's Avatar
Default
Quote:
Try these lines. OEM Bosch units at a unbeatable price!
http://lincolndieselspecialties.com/...line-left.html
http://lincolndieselspecialties.com/...ine-right.html
__________________
Phone: 920-361-7700
  #10
Old 08-17-2018, 12:59 PM
FNG
Default
they crack and fall apart, eventually pop off and pour diesel everywhere
  #11
Old 08-17-2018, 02:22 PM
PureHybrid's Avatar
Isuzu Shakes IT
Default
If you don't want to spend $120+ for both Bosch sets, you can get a whole roll of the Gates hose for $50 sometimes cheaper. Part # is 27121 I think.
__________________
8.17@84mph 1/8mi
Jesse
  #12
Old 08-17-2018, 10:38 PM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
Default
And then sell remainder of the roll to a buddy and recover most of your $50...
  #13
Old 08-18-2018, 05:50 AM
PureHybrid's Avatar
Isuzu Shakes IT
Default
Quote:
Hey now, only half
How much of that did you end up using?
__________________
8.17@84mph 1/8mi
Jesse
  #14
Old 08-18-2018, 06:32 AM
Ne-max's Avatar
I like turtles
Default
The hose is not the issue. It's the cheap plastic fittings and oring.
__________________
2013 ccsb Tow rig
2006 rclb 6.6
  #15
Old 08-18-2018, 09:28 AM
kidturbo's Avatar
Piston Tester
Default
Hey now, only half
I've only used about 10' off that spool so far.
One thing I've learned about rubber fuel lines on diesels, prior to like 2011 much of the OEM stuff wasn't very biodiesel stable. Biodiesel properties will cause some rubber compounds to dry out and crack, and BioD eats natural rubber for lunch.
I ran high percentages of BioD on a couple LLY setups without noting any return line issues. But on the wife's 05 MB CDI, everything besides the injector returns had to be replaced after just a year or so. It's a Euro thing.. Running high percentages of bio is like accelerated testing of the typical 5-20% bio you might be encountering in typical pump diesel.
As mentioned above, on the LBZ you shouldn't have any back pressure on returns. If that's all good, pick a better material. AND make sure it's the correct size line..
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
