Old 10-06-2018, 08:14 AM
Leonard Simmons Leonard Simmons is offline
FNG
Default Wiring Harness mounted on fender insert
So when I have to replace glow plugs, on the driver side of my LMM I have to pull the fender liner, but the damn wiring connectors are mounted to it, so you have to pull those off, and then getting them back in is a beast. they are under the fuse block, any tricks to that one, I tie fishing line to them and thread the line through the holes in the fender liner and pull them back in later, got to be a better way, Im sure I am doing it wrong, also my ecu is mounted to my fan shroud? with one small plastic fastener, any tips on securing this better so it dose not come off on good bump in the trail?
Old 10-06-2018, 08:30 AM
Jacy_dzlguy Jacy_dzlguy is offline
lots to learn...
I usually just leave them hanging. If you’re worried about it just ziptie them to something before you install the fender. But what do i know i live in Florida and don’t usually run fenders..
2011 LML CCSB 4x4
No exhaust-Tune-Airdog-HSP air piping-lowered-
2008 LMM SCLB 2500 converted to 3500 dually flatbed
O6 LLY GMC SLT 4X4 (sold)
2005 LLY SCLB (sold)
Old 10-10-2018, 07:41 PM
tjs82's Avatar
tjs82 tjs82 is offline
Gearhead
Usually I wrangle the liner into the fender, and leave it sort of hanging loose. Then attach the connectors onto the liner first before bolting anything in. My liners have been in and out quite a few times though, so the holes for the connectors are pretty clapped out. You could always tie them to the underside of the inner fender (the part of the fender that the fuse box bolts to) instead of the liner. It would make life easier if you have them in and out on a regular basis. I'd either make sure the harness isn't rubbing on the edge of the fender (it's pretty damn sharp), or make sure that section of the harness is protected, so it doesnt rub through.
07.5 CC/SB LMM
EFILive with DSP5 tuning, Kennedy lift pump, Limitless trans built by yours truly, 1078 converter
Old 10-10-2018, 08:21 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Originally Posted by Jacy_dzlguy View Post
I usually just leave them hanging. If youíre worried about it just ziptie them to something before you install the fender. But what do i know i live in Florida and donít usually run fenders..
2x
2008 Chevrolet 3500HD DRW LTZ
