Old 08-20-2018, 11:27 AM
duramaxzak's Avatar
duramaxzak duramaxzak is online now
Wanna be puller!
Default LB7 short block in LBZ truck
To put a LB7 short block into a LBZ truck I only have to switch the reluctor wheel and front cover correct?
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
Old 08-20-2018, 07:29 PM
duramaxzak's Avatar
Wanna be puller!
70 views and not one reply....
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
Old 08-20-2018, 07:43 PM
gmduramax's Avatar
Shits broke
Oil pesssure sensor in a different spot?
10.98@124mph
Tailgate Crew Member #1
Old 08-20-2018, 07:45 PM
duramaxzak's Avatar
Wanna be puller!
I believe the 03-04 LB7 are in the same spot as a LBZ.
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
Old 08-20-2018, 07:50 PM
gmduramax's Avatar
Shits broke
I think that and the reluctor wheel are the only differences
10.98@124mph
Old 08-20-2018, 07:55 PM
rfletes79's Avatar
rfletes79 rfletes79 is online now
Cam and crank sensors. Yes 03 and up eop sensors are the same and in the same location.
j
1970 Chevelle Duramax Hot Rod, '04 LB7/TH400-gear vendor, HTT 67.7 FMW, Wagler street intake, 65% S&S sticks, exergy 10 mil pump, SoCal AF3388, Valve springs, Push Rods, LBZ rods, cut LB7 slugs..... 9 sec cruzer :-)
2002 2500HD LLY 6 speed ally conversion
Old 08-25-2018, 02:53 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Can the cam & crank sensors just be swapped into the lb7/LLY front cover? So you'd be using a lb7/LLY short block including timing cover and water pump but lbz reluctors and sensors?
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
