  #721
Old 10-15-2018, 06:49 PM
dmax_ty dmax_ty is offline
Default
Looks like Kory is the first to offer it for purchase at this point. Pony up $4100 and it’s all yours.
__________________
2k18 CC/SB GMC
I have a problem.
  #722
Old 10-15-2018, 07:01 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default L5P Tuning
Quote:
Originally Posted by dmax_ty View Post
Looks like Kory is the first to offer it for purchase at this point. Pony up $4100 and itís all yours.
Looks like he already offers soft tuning and switch already.
__________________
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #723
Old 10-15-2018, 09:03 PM
chavez91's Avatar
chavez91 chavez91 is offline
Standing Bear
Default
Quote:
Quote:
Originally Posted by othrgrl View Post
Because SOTF is nothing more than an electronic throttle stop that taps into a sensor circuit that he can use as a fuel limiter based on voltage. It is nothing at all like DSP5 from EFI Live where there are actually separate tables for all of the key things in the tuning to completely change how the truck runs at any and all throttle positions. Hell, if you know what the limiting table in the stock tune looks like for the sensor you at tapping into you can set up a switch with resistors to hit voltage set points and limit fuel to what you want, even on a stock tune.
Let's just say that something better than that FAKE switchable is coming soon.... Because with these fuel temp limit styles, you might as well just run a single tune.
__________________
Josh
'04 GMC LLY
*Build Back In Progress*
505K Miles
'05 GMC LLY
LML Hybrid, 6-Spd Conv. ML Trans
Fuel Coming soon.
300K Miles
'17 GMC L5P
Peach Habanero Spicy Tuna
Big thanks to Mike L., Ira, James, Nate, Jon, Steve, Nick.
  #724
Old 10-16-2018, 04:08 AM
TheBac's Avatar
TheBac TheBac is offline
Default
SOTF?
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #725
Old 10-16-2018, 04:40 AM
gmc502 gmc502 is offline
Default
switch on the fly
__________________
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
  #726
Old 10-17-2018, 09:34 AM
Rivera.alan's Avatar
Rivera.alan Rivera.alan is offline
Gearhead
Default
I need a gofund me setup for me to free mine up
__________________
L5p
DDP Intake Pipe
DDP Intercooler Pipe
Cognito leveling kit
Cognito Pisk
Fox Shocks
Mike L dummy trans solenoid
18x9 +18 Method wheels
295/70/18 Nitto Terra G2's
LB7 - Sold
  #727
Old 10-18-2018, 07:26 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Ok guys. The DSP discussion seemed to be taking over this thread. I know we're pretty liberal with thread derails here, but the L5P tuning is new enough that it doesn't derve such a massive derail on an active thread. In the interest of keeping the discussion a little more on topic, I moved all the DSP stuff to a new thread. Please see the post here. Carry on!
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #728
Old 10-18-2018, 12:30 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
So if the ez link can flash a factory tune into the ecm why does hp tuners need to modify the ecm to accept their tune? Is this like needing an unlock tool for the 13+ Cummins and years later Efi LIVE finally decided they can do it without it?
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #729
Old 10-18-2018, 01:19 PM
JoshH's Avatar
Default
Quote:
I'm going to guess it has something to do with security protocols and code verifications before the ECM will accept a flash. From what I understand, once the ECM is unlocked by HPTuners, the factory equipment can no longer flash it.
__________________
  #730
Old 10-18-2018, 01:34 PM
gmduramax's Avatar
Shits broke
Default
Quote:
So then I wonder if gm can even hook to it and tell if itís been flashed, of course if not than they would suspect something is up. But can they void your warranty if they canít pull the codes off of it.
__________________
10.98@124mph
  #731
Old 10-18-2018, 01:51 PM
onebaddmaxxx onebaddmaxxx is offline
Default
Factory equipment cant flash it. Doesnt mean it cant read codes.
__________________
2005 lly-tow rig
2006 lbz- 4l80e, single s476, 200s, 2xcp3 4500lb
  #732
Old 10-18-2018, 02:12 PM
GMC_2002_Dmax's Avatar
GMC_2002_Dmax GMC_2002_Dmax is offline
The Still Master
Default
The factory ECU Chip is being replaced with a NON GM Controlled chip.
That is part of the reason why the cost is so high for the unlock, IIRC is a 516 PIN EEPROM that is bedded in a hard epoxy like coating, the removal process requires heating it and carefully removing the factory chip without damaging the rest of the ecm and the board, then resoldering a replacement chip.
No JTAG or BOOT Method is possible from GM with this ECU, so once HP Tuners has their own chip on the ecm they shut the door on GM and everyone else................
So that is the current process for this ECU, if someone figures out a way to undo HP Tuners control and then flash it with a process they control then see the fireworks begin.
__________________
2019 Denali L5P - New Test Truck
2016 Denali LML
-> SOLD
2012 Denali LML - > SOLD
2007 GMC "Classic", LBZ, SLE1 ,RC/LB,
12.525 at 107.07 - > SOLD
2002-GMC Sierra 2500HD SLE/CC/SB/4X4~Powered By "MOONSHINE"
12.65 fuel only, 12.00 on some N20
Retired 04/18/2009 -> SOLD
  #733
Old 10-18-2018, 09:51 PM
gmduramax's Avatar
Shits broke
Default
6500lb L5P went 12.3 @108. Should be 550hp to the tires.
__________________
10.98@124mph
  #734
Old 10-19-2018, 04:03 AM
036.6turbo 036.6turbo is offline
Default
Quote:
That is part of the reason why the cost is so high for he unlock, IIRC is a 516 PIN EEPROM that is bedded in a hard epoxy like coating, the removal process requires heating it and carefully removing the factory chip without damaging the rest of the ecm and the board, then resoldering a replacement chip.
Hmmm, that has some ramifications? So who's diagnostic software / hardware will be used?
How can Mike L yell at guys for not reading trans codes with a TECH II, if the door is shut? (On these 2018 and newer trucks will a TECH II even still work, or are they MDI only?)
Or is the plan to put the factory ECM back in whenever diagnostics need to be performed?
Maybe HP tuners has all the same diagnostic abilities a TECH II or GM MDI does?
I sure they have thought of all this, just curious how they plan to do it.
__________________
2003 GMC Sierra CCSB.
LBZ / Six speed / EGR Delete / DSP5 with tuning from Idaho Rob @ ATP Trucks / Bilstein 5100s / Air Ride 5000 bags / Merchant Reman Tcase / TNR head unit.
2015.5 Denali. Dmax Allison / Exergy Sportsman CP3 / WCFab "Y" Bridge with cold air bundle / WCFab 3" downpipe / LB7 up pipe / 4" Flo Pro exhaust / FASS 150 / Sump / AirLift 5000 bags with WirelessOne on board air / B&W Turnover ball / AMP Research power steps.
  #735
Old 10-19-2018, 06:41 AM
chavez91's Avatar
Standing Bear
Default
He was close. But not quite.
TIS/GM/dealer flash won't work.
Everything else is a go
__________________
Josh
'04 GMC LLY
505K Miles
'05 GMC LLY
Fuel Coming soon.
300K Miles
'17 GMC L5P
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
