  #16
Old 03-15-2019, 03:34 PM
Burn Down's Avatar
Nice job! Good motivation.
Going to try like heck to get my Std cab put together this summer.
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #17
Old 03-15-2019, 03:42 PM
JoshH's Avatar
JoshH JoshH is offline
What a steaming pile... Must have been worked on by a bunch of hacks.
06 Silverado 4x4 CC/SB
  #18
Old 03-15-2019, 04:14 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Awesome job.
What is the large cooler with the lines coming around the drivers side of the rad?
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #19
Old 03-15-2019, 04:37 PM
Robby Avery's Avatar
Robby Avery Robby Avery is offline
GM TECH @ FENDER GMC
Nice build subd is steed speed finally going to make dmax manifolds available now or are they still testing the market?
2006 Chevy 2500HD LBZ Duramax Summit White CCSB Tan (neutral) leather LT3 pkg w/sunroof OEM bra 4x4, ISSPRO EV, ATS Twin CP3's, Built Allison, Eaton E-locker front stock G80 rear, Kennedy Twin pump filter combo kit, Snow Perf Stage 2 w/m injection, 4in to 5in banks tip, HM Big K&N, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Rancho RS9000XL, Fabtech HD TR, Cognito P&I Brace kit, DD/Puller/Work Truck
2002 Chevy 2500HD LB7 Duramax Summit White CCSB Grey (neutral) leather LT3 pkg OEM bra 4x4, Kennedy Twin Pump Filter Combo Kit, ISSPRO EV, PPE Boost Valve, DTS Built Allison, MikeL Cooler, ATS Billet Flexplate, DTS 3in DS IC pipe, Bill's 5in CAI (White), Big K&N, 4in to 7in black stack, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Cognito P&I Brace kit, Sleeves, Energy Sway bar Kit, DD/Puller/Work truck
Special Thanks: (David) DTS, (Guy) Socal Diesel, (Nick & crew) DuramaxTuner, (Dan) PPE, (John) Kennedy Diesel, (Tony) All Season
  #20
Old 03-15-2019, 05:44 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
Originally Posted by coker6365 View Post
Thanks guys. If it's not fun and frustrating at the same time then it's not worth doing.
Sent from my SM-G930V using Tapatalk
I know the feeling, my reg cab has been having water pump issues as well, I had to plug weld the pump pulley on it.
I love this thread...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
  #21
Old 03-15-2019, 06:51 PM
JoshH's Avatar
Originally Posted by ikeG View Post
Awesome job.
Engine oil cooler.
Last I heard, they are currently being manufactured for public release.
  #22
Old 03-15-2019, 06:55 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Why such wide tires? Seems like they would ruin aerodynamics.
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #23
Old 03-17-2019, 05:48 PM
Engine oil cooler.
Good to know how did they effect egts and spool time?
  #24
Old 03-18-2019, 05:55 PM
coker6365's Avatar
coker6365 coker6365 is offline
Coker6303's ***** Daddy
Hello, McFly... Stance!
2015 Denali CC/SB LML
2013 RC/LB LML
2006 RC/LB LBZ, SXE472/87/1.0 & FI491/100/1.45, 250% F1 Injectors, Dual 10mm CP3, SoCal Built Engine, JoshH Built Trans, JoshH Tuning. 10.18 @ 140mph and still going...
Big thanks to Josh Harris, Josh Chambers, and my brother Russell Coker for all the help with the LBZ.
  #25
Old 03-18-2019, 05:59 PM
coker6365's Avatar
EGT's are the same, spool feels tad better but it's very difficult to tell since I changed 1500-2000ft in elevation when I swapped them on and we did not log spool time before. Haven't been back to the good air with them yet.
The data Leen has on them from an engine dyno compared to cast manifolds shows a touch more hp and a tad less drive pressure back to back. So I would assume the scavenging effect is helping somewhat. Biggest benefit I have seen is they have not blown gaskets with numerous pulls and some dyno time. They are holding up very well for us.
2013 RC/LB LML
  #26
Old 03-18-2019, 06:45 PM
Ne-max's Avatar
I like turtles
Chit. Ya. You Texans have to have that.
2013 ccsb Tow rig
2006 rclb 6.6
  #27
Old 03-23-2019, 12:06 AM
slowlml's Avatar
slowlml slowlml is online now
Wehrli has them available
Nic
2011 ccsb
Some stuff to make it blow up sooner.
