  #1
Old 09-11-2019, 10:40 AM
Nickracer9 Nickracer9 is offline
Default Hsp triples S369ís for sale
Selling a barely used triple kit designed over a LMM valley vgt turbo. Kit comes with turbo smart blow off valve, custom vband down pipe, hsp coolant pipe, billet y bridge, valve cover breathers, and coolant tank. Everything is in like new condition. Asking $6000. Also have a valley Danville 68stg2r with upgraded turbine which I’d sell with it for $1750. Set up was hitting 100 psi with my socal stage 1 heads. Kit is currently on truck but can be removed ASAP. Thanks for looking!
__________________
09 Lmm/Lml SoCal Diesel Stg3 engine. Danville performance 68stg2r/S483 tct, Exergy 150% over, Exergy 12mm, built billet tranny by Limitless diesel and me. Ecm/Tcm tuning by Danville performance. Hsp Triples S369sxe coming soon!
  #2
Old 09-13-2019, 05:36 AM
Default
Bump $5500
__________________
  #3
Old 09-20-2019, 06:45 AM
Default
$5250 bump
__________________
  #4
Old 10-17-2019, 07:53 AM
Default
$5000 bump
__________________
  #5
Old 10-26-2019, 08:19 AM
Robby Avery's Avatar
Robby Avery Robby Avery is offline
GM TECH @ FENDER GMC
Default
Will this work on 06 lbz?
__________________
2006 Chevy 2500HD LBZ Duramax Summit White CCSB Tan (neutral) leather LT3 pkg w/sunroof OEM bra 4x4, ISSPRO EV, ATS Twin CP3's, Built Allison, Eaton E-locker front stock G80 rear, Kennedy Twin pump filter combo kit, Snow Perf Stage 2 w/m injection, 4in to 5in banks tip, HM Big K&N, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Rancho RS9000XL, Fabtech HD TR, Cognito P&I Brace kit, DD/Puller/Work Truck
2002 Chevy 2500HD LB7 Duramax Summit White CCSB Grey (neutral) leather LT3 pkg OEM bra 4x4, Kennedy Twin Pump Filter Combo Kit, ISSPRO EV, PPE Boost Valve, DTS Built Allison, MikeL Cooler, ATS Billet Flexplate, DTS 3in DS IC pipe, Bill's 5in CAI (White), Big K&N, 4in to 7in black stack, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Cognito P&I Brace kit, Sleeves, Energy Sway bar Kit, DD/Puller/Work truck
Special Thanks: (David) DTS, (Guy) Socal Diesel, (Nick & crew) DuramaxTuner, (Dan) PPE, (John) Kennedy Diesel, (Tony) All Season
  #6
Old 10-26-2019, 07:20 PM
Madspeed's Avatar
Madspeed Madspeed is offline
Fat Bastard
Default
Quote:
I think its just the map sensor bung is different. I swapped out my LBZ electronics to LMM and that was all the hardware I found different
__________________
71 2WD 4X4 1ton conversion, LB7 TT SCV and some other shit/ OOPs I found a suburban to melt into the pickup and make a CC longbed 71 4x4. back under the knife for the 71
2007 Suburban LBZ/LMM Lifted and shit. Fingers ovals, Socal Stage 2 cam, Socal stage 1 heads, SoCal billet mains, ats damper, Danville stg 2 bmw, 480SXE, PPE dual fueler, ARP studs top to bottom, Danville tuning
  #7
Old 10-27-2019, 06:23 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
Quote:
Maf
__________________
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #8
Old 11-06-2019, 09:12 AM
Default
Bump
__________________
  #9
Old 12-10-2019, 01:35 PM
Default
To the top!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vB.Sponsors
