  #1
Old 09-05-2019, 07:04 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Default James is retarded and thought an actual lly was an 06
THREAD MOVED FROM FOR SALE THREAD FOR FUTURE REFERENCES
Quote:
Originally Posted by Chilly View Post
I have one for sale. Check out my ad.
https://www.duramaxdiesels.com/forum...ad.php?t=83102
The damper you have listed will only work on 06-10. He needs 01-05 which is Fluidampr PN 890101. 06 LLY shares nothing with 04.5-05 LLY in regards to hard parts interchangeability. 06 LLY is just a LBZ with a lower power tune.
__________________
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-1340hp/2200ft-lbs @ ATS Diesel (06/04/19)
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, F1 Diesel 275% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend AR Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, "Budget" Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
Last edited by Chevy1925; 09-06-2019 at 09:33 AM. Reason: moved posts, off topic. edit to explain
  #2
Old 09-05-2019, 08:26 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Quote:
Not true. If itís an early 06, it will be a true lly. Jan to May of 06 iirc were the months. And those are very much out there
If it has a ficm at the pass front of the engine, it ainít no lbz
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
  #3
Old 09-05-2019, 08:56 AM
Bdsankey's Avatar
Gearhead
Default
Touche, I've never worked on an early 06 then. Every 06 that has come into my shop has been LBZ based (no ficm).
__________________
K&D Service Inc
Current Rides:
  #4
Old 09-05-2019, 08:03 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
So an early 06 LLY has a ficm on the valve cover?
__________________
"OldManTan"
04 SC/SB 1500 Dart 427ci, AFR 6 bolt heads, twin 80mm turbos, TH400 [email protected] so far..
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
  #5
Old 09-05-2019, 08:12 PM
Chevy1925's Avatar
Default
Quote:
Wanna see pics this weekend lol? Yes sir. 5 speed trans as well.
__________________
James
  #6
Old 09-06-2019, 08:01 AM
Getting faster
Default
I never knew that. Mind blown
__________________
"OldManTan"
  #7
Old 09-06-2019, 09:30 AM
Chevy1925's Avatar
Default
same here. i ordered an LBZ reg to replace his because i thought like everyone else and when i popped the hood, i saw that the fan didnt have a cage on it and it was black. looked over and saw the ficm and popped under the cab to look for an NSBU, sure enough, right there on the outside. pulled the new lly reg off my second pump and sent the LBZ reg back for another new LLY reg.
these bastards are out there
__________________
James
  #8
Old 09-06-2019, 09:32 AM
Chevy1925's Avatar
Default
pulled our little off topic discussion out of the for sale thread for future reference.
__________________
James
  #9
Old 09-06-2019, 09:36 AM
Bdsankey's Avatar
Gearhead
Default
__________________
K&D Service Inc
Current Rides:
  #10
Old 09-06-2019, 09:52 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Sorry James, but you are wrong. I have an 06 LLY that was built in 08/05. It does not have a FICM and does have a 6 speed Allison.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #11
Old 09-06-2019, 10:25 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
I've never seen one either and I've seen a lot of Duramax trucks.
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #12
Old 09-06-2019, 10:37 AM
Chevy1925's Avatar
Default
ill take a pic of the door sticker and what not tomorrow. maybe i am retarded, swore the door plate says 04/06 on it. maybe dyslexia kicked in
__________________
James
  #13
Old 09-06-2019, 12:07 PM
JoshH's Avatar
Default
Either dyslexia or someone did a powertrain swap. A build date of 04/06 would have for sure been an LBZ. I think they started in late Oct. 05. I know I bought mine at the end of September, and it was going to be about another month before LBZ production started.
__________________
  #14
Old 09-06-2019, 01:15 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
Lol, this is how those stories get started. "My buddy has a 6.0 with an allison" etc
Sent from my SM-G960U using Tapatalk
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #15
Old 09-06-2019, 01:35 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
So has anyone seen LLY injectors in a 06 LBZ
__________________
2008 GMC duramax crew cab short bed 2500.
[email protected]
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vB.Sponsors
