  #16
Old 01-10-2019, 11:13 AM
N2BRK N2BRK is offline
Default
my 08 OEM filter/box wasn't good at 600hp. I'd suck the minder down into full red with one highway pull. I went to a plastic rotomoulded Injen with a dry filter. When I hit the dyno at Mark's he said fuel and not air was my limiting factor at 636hp. I've since gone to a 12mm cp3 from stock and the minder needle on the Injen doesn't move on the big(ger) tune. The filter is gigantic, BTW. The airbox barely fits because it's so big. I'm pleased.
__________________
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
  #17
Old 01-10-2019, 11:16 AM
Default
this one https://www.injen.com/evo7003.html.html
__________________
08 LMM Crew 4x4
Exergy 12mm
  #18
Old 01-10-2019, 02:01 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
I love seeing threads like this pop up. Lots of good info here. Wasn’t aware that some guys were steering away from factory setups. My truck came with a banks I take and exhaust and I’m starting to wonder if the exhaust is choking me. Even with a good tune whether I baby if beat it I get 15mpg constant hand calculated.
__________________
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #19
Old 01-10-2019, 08:25 PM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Default
Who’s tuning? Tire size? Gears? Lift? Mods?
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-1340hp/2200ft-lbs @ ATS Diesel (06/04/19)
-Built Motor, Tuned by Zach @ Starlite, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #20
Old 01-11-2019, 04:55 PM
zakkb787's Avatar
<thatís not me...
Default
Quote:
Originally Posted by Bdsankey View Post
Whoís tuning? Tire size? Gears? Lift? Mods?
Corbin tuned it. Great clean tune. But no change. All his other guys get 18-19 ish. 33x12.50. Stock gears Iím assuming 3.42? Truck has a leveling kit turned down an inch below level. Just a tune, banks intake and banks exhaust. No change from stock tuning and stocks with 285s.
__________________
Other toys:
2011 Yamaha YFZ450X
2018 GasGas XC300
  #21
Old 01-11-2019, 07:27 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
Quote:
Originally Posted by Chevy1925 View Post
that doesnt mean much. your visual test and butt dyno will never be able to tell you the difference. your MAF sensor will trick you.
James, I'm sorry to disagree with you as I have allot of respect for you. But my truck has zero smoke and it's dropping rail down to 24-25k on the big tune. Zero smoke on stock intake.
Dropping rail and no smoke, the 3794 is doing it's job well and so is the stock intake
Not saying there isn't more power to be had.
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #22
Old 01-11-2019, 07:33 PM
gmduramax's Avatar
gmduramax gmduramax is online now
Shits broke
Default
It would spool better and make more power with a good intake. No if ands or buts. If youíre happy with how it performs, great. Thereís more to be had.
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #23
Old 01-11-2019, 10:22 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Iíll never fault ya for being happy with your rig . Dont fix what ainít broke
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #24
Old 01-12-2019, 07:20 AM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
I know my truck picked up 37hp on the dyno with a 4094 68r, 60% overs, 10mm pump the second we removed the S&B filter. I left the airbox there just pulled the element. We did 5 runs filter on and 5 runs filter off and the average gain (peak) was 34.8hp. The curve was also fatter down low but not enough to write home about.
So you gained 35hp unfiltered on an 800hp truck?
Quote:
Originally Posted by N2BRK View Post
Not a bad price. I've never seen one in person. Everyone always seems to run S&B, AFE or a filter on a stick.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
8.17@84mph 1/8mi
Jesse
  #25
Old 01-12-2019, 07:52 AM
Bdsankey's Avatar
Gearhead
Default
Quote:
I wish it was an 800hp truck. On the dyno it was tuned on it did 671/1186. Never went to the track to get an ET/MPH on it to see if that was accurate or not. The tuning in the truck could've been better but I chose to have it dyno tuned by a shop in northern WI.
__________________
Current Rides:
  #26
Old 01-12-2019, 10:14 AM
Default
I talked to the designer before buying it. I was very skeptical. But owning it, Iím very pleased. Itís a huge dry nanofilter in the biggest box you could fit. All plastic and sucks from the fender. My only gripe is filter changing is a pain, but 10mins and a few tools now and then wonít kill me.
__________________
08 LMM Crew 4x4
Exergy 12mm
  #27
Old 01-12-2019, 11:23 AM
PureHybrid's Avatar
Isuzu Shakes IT
Default
I was under the impression it was the LLY listed in your signature. What turbo is on the lb7?
Thinking about buying one. I have a Bill's intake from back when he was still making them, the smaller air box makes it hard to fit a big filter in there, so I've been pulling the filter at the track
__________________
8.17@84mph 1/8mi
Jesse
  #28
Old 02-10-2019, 12:42 PM
Columbus450's Avatar
Columbus450 Columbus450 is offline
Default
Well I just installed the new WCfab CAI I noticed immediately how responsive the spool up time is WOW !! Very happy about that, But on the other hand my truck rolls mad coal now , It was way way cleaner before all I did was add a Turbo mouth piece and cai , I guess I will have to contact Eric long I'm thinking maybe the MAF needs recalibration I'm not sure.... ?https://cloud.tapatalk.com/s/5c607e89...120629_001.mp4
Sent from my SM-N960U using Tapatalk
  #29
Old 02-10-2019, 12:44 PM
Default
I upload the video let me know if you guys could see it and tell me what you think like I said For the most part it was very clean before this is on Tune 5 WOT after cai swap
  #30
Old 02-10-2019, 12:58 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
So you are not talking about the 820 hp truck in your sig .
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
