Old 02-11-2020, 10:25 PM
20dmax08 20dmax08 is offline
Gearhead
Default Curious about semi turbos
Was curious if you could use a turbo for say a 60 series Detroit or a cat or something similar in a compound setup?? Iím sure been asked. Tried google couldnít find anything. Thanks.
2008 Chevrolet ccsb 2500 - egr/dpf deleted, pcv rerouted, bd drivers manifold, dmaxstore downpipe, 5Ē exhaust, s&b cai, arp head studs, htt promax 64, ppei tuned, limitless diy kit installed by me, limitless 1078 converter, goerend Allison deep pan, fass lift pump
Old 02-12-2020, 12:12 AM
LBZ's Avatar
LBZ LBZ is offline
Their turbos are generally a little loose in the a/r area for our use. Take a lot more heat and fuel to light.
Would it work sure but not the most ideal setup.
Old 02-12-2020, 06:11 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Simple answer is yes but not really recommended like said above. They are designed for engines 2x to 3x the displacement of a duramax and can get away with the looser AR on the turbine side.
Now a Borg 475/96/1.15 or 1.32 T6 is relatively cheap for a box cast charger for something to put over a stock turbo and get stellar results.
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, F1 Diesel 275% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend AR Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, "Budget" Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
Old 02-12-2020, 02:07 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
My turbo in my 3406E Kenworth is a S480. 80/96 1.45 T6
"OldManTan"
04 SC/SB 1500 Dart 427ci, AFR 6 bolt heads, twin 80mm turbos, TH400 [email protected] so far..
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
Old 02-13-2020, 09:13 AM
Gearhead
Thanks gents. Didnít see a lot about it and was curious. Thanks for enlightening me! I want to compound my duramax and trying to find alternate routes. Iím in Canada and our dollar is shit. Lol
Old 02-13-2020, 09:52 AM
Bdsankey's Avatar
Gearhead
Originally Posted by 20dmax08 View Post
Thanks gents. Didn’t see a lot about it and was curious. Thanks for enlightening me! I want to compound my duramax and trying to find alternate routes. I’m in Canada and our dollar is shit. Lol
What turbo are you trying to compound over? If it's a stock turbo or a smaller drop-in a S475/96/1.32 T6 is a cheap option from any Borg Warner dealer in Canada. While better spoolup characteristics can be had with the tighter 1.15 T6 housing, I wouldn't consider it a necessity as it will run great with the 1.32 housing.
The Borg Warner PN is 171702 for the S475/96/1.32 T6. The PN for the 1.15 T6 housing is 14961019007. Another option is buying a turbo from the states and having it shipped in but I am not familiar with how pricey that can be.
K&D Service Inc
Current Rides:
Old 02-13-2020, 01:55 PM
Gearhead
I have a htt promax 64 in the valley. I wonít be looking for big power under 750rwhp. Just want good towing and street. Was thinking of using hsp plumbing with factory battery. I have their y-bridge and cai and like their products. if I can get turbo here cheaper thatíd be great.
Put it to you this way. If I got $1000 turbo in the states and shipped to the place I pick up in Montana itíd likely end up costing me $1500 Canadian or so.
