  #46
Old 11-17-2016, 06:18 AM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
Default
Quote:
Originally Posted by kiwilml View Post
So just out of curiosity, how much boost does it build free reving at 4200?
Maybe 1 pound if that lol, need to see if I can get a tune for that. Maybe play with vein position.
__________________
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
  #47
Old 11-17-2016, 06:33 AM
Josh154's Avatar
Josh154 Josh154 is offline
Default
I'm sure there's a way to set it up so you can hold more boost between gears. I have a Subaru sti and I have flat foot shift setup through my accesport which holds boost between gears. It's literally the same thing you do except it has a rev limiter that I can set so it won't free rev to the moon lol. I usually set it at 6800 and shift around 6500. Nice times btw, I was about to order a sportsman pump a month ago but I'm glad I didn't lol.
__________________
16 CCSB LML - SDP cp3 conversion, exergy sportsman, SDP y bridge intake & intercooler pipes, 3 downpipe, 5 jamo exhaust, lb7 up pipe, fass titanium 165, deviant sump, epc fooler, UDT tuned
08 CCSB LMM - HSP 369sxe kit, 10mm S&S cp3, built trans with suncoast 1058, supporting mods and Danville tuned
SOLD
  #48
Old 11-17-2016, 06:48 AM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Just to clarify on everyone's idea his sportsman is no good.. Jesse is running Max effort stock injector tuning and then put 45%s on the truck and did not change the tuning.. There's a lot of fuel being commanded.
Of course he could always add another pump and leave the pulse where it is good bye parts
__________________
03 reg cab. Low and slow
07 crew long classic- stolen
  #49
Old 11-17-2016, 08:02 AM
zf>allison's Avatar
Default
My theory is if I try not to worry about it and make it light as possible and just cross my fingers lol
__________________
best
Instagram-636zf6
  #50
Old 11-17-2016, 08:05 AM
zf>allison's Avatar
Default
It holds no boost at a free rev to launching but powershifting between gears i dont lose much boost, but I spike 40 pounds in 6th on the stocker
__________________
best
Instagram-636zf6
  #51
Old 11-17-2016, 08:09 AM
clrussell's Avatar
pro-procrastinator
Default
Quote:
I still think we should short bed it and cut the bed floor out
__________________
  #52
Old 11-17-2016, 08:37 AM
zf>allison's Avatar
Default
Not opposed but I wanna half ton swap it first
__________________
best
Instagram-636zf6
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
