  #1141
Old 01-15-2020, 01:27 PM
2004LB7's Avatar
2004LB7 2004LB7 is online now
Originally Posted by kidturbo View Post
Yeah it does. Wonder if they sell it separate from a pump however?
Sent from a russian troll farm using Tapatalk
Wreaking yards or pick and pull?
2008 Chevrolet 3500HD DRW LTZ
  #1142
Old 01-15-2020, 01:43 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
That was a rare engine in that car. I've never seen one in a junkyard. Only seen one in the wild even.
  #1143
Old 01-15-2020, 01:48 PM
Chevy1925's Avatar
fiddy foe bucks
https://www.ebay.com/itm/2005-Pontia...temCondition=4
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
  #1144
Old 01-15-2020, 02:14 PM
2004LB7's Avatar
How about these guys
https://www.lsxconcepts.com/products...return-fitting
  #1145
Old 01-15-2020, 02:16 PM
Chevy1925's Avatar
^^ oh i like that
James
  #1146
Old 01-15-2020, 04:34 PM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
That's so funny. Just ordered 2 of his press in 10AN 90s before seeing that post. Be here Friday.
All said and done, would probably been cheaper to order the TuffStuff pumps with both AN fittings installed.. Had I known what model pumps to order...
  #1147
Old 01-15-2020, 04:38 PM
Chevy1925's Avatar
Hindsight..... lol
James
  #1148
Old 01-15-2020, 04:54 PM
kidturbo's Avatar
Piston Tester
Now ow many more 90s will it require to tuck a -10 & -6 fitting and hoses in there behind the belt tensioner??
On a side note, the mechanical monsters heads are shaping up nicely.
  #1149
Old 01-16-2020, 07:33 PM
kidturbo's Avatar
Piston Tester
Accessory bracket cut, and after a little trim I think we are all good to go on front end assembly tomorrow.
Ever notice how when your looking for a cheap piece of 1/4" polished aluminum none is ever arround? Not to worry some will always show up when you fully intend to powder coat the pieces you had cut....
  #1150
Old 01-16-2020, 09:11 PM
gmac32 gmac32 is offline
Looks really good
2011 denali gmc 5.5 lift, 35" tires, carillos, cut, coated lml pistons, hot cam 63.5 mm vgt over billet s480, fox shocks, profab manifolds and up pipes, intercooler pipes, 10mm cp3, ported heads, valve springs
  #1151
Old 01-17-2020, 07:25 AM
Chevy1925's Avatar
is there any way to turn the pump so the feed for the pump has gravity pushing it in? power steering pumps dont like to have to do any kind of "pulling" of the fluid when it comes to the feed side. you start to get cavitation and whining of the pump. might work ok at idle but as rpm increase, they get worse.
James
  #1152
Old 01-17-2020, 04:09 PM
kidturbo's Avatar
Piston Tester
I upgraded all of the hose to 5/8 -- 10 AN as recommended by every power steering guy I've spoken to... The reservoir is above the pumps, but mounted 4 feet away on side of engine bay. So it should keep a little head pressure on em.
Since there will typically be two pumps running, the load on each should only be half of a single pump.
Will see you shortly...
  #1153
Old 01-17-2020, 04:38 PM
Chevy1925's Avatar
, I think you will run into issues but hopefully not.
Power steering pumps are very temperamental on keeping good flow of oil to the pump. Had a long travel raptor try something similar to that and it whined soon as things got warm. Also had a buddy with a rock buggy with the hose parallel to the pump from the resi, wasnt enough and the thing would cavitate real bad as soon as you yanked the wheel back and forth 2 times. That was a full hydro setup.
James
  #1154
Old 01-17-2020, 07:20 PM
kidturbo's Avatar
Piston Tester
I'm betting the wine of the turbos will cover the sound of the power steering pumps cavitating. Problem solved.. LOL
Like everything that's custom, you never know if it will work till you bolt it up and give it a try. Kinda like these brand new LBZ alternators I'm cracking open and modifying so I can clock the terminal where they fit where they fit the build.. Custom...
  #1155
Old 01-18-2020, 06:44 AM
NC-smokinlmm's Avatar
<<<Future tuna killer
Boats, you have to customize everything...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
gmc502
