Old 03-01-2020, 06:58 PM
Pwinland95's Avatar
Pwinland95 Pwinland95 is offline
Gearhead
Default Fuel pressure issue
So I have a cab & chassis shop truck at work, drove it one day last week and it threw a p1093 code. Truck quit running and would not start. Changed the fuel filter, also replaced the transfer pump that pumps fuel from one tank to the other. I can get it running on starting fluid but if you shut it off, it will not start again. Seems like it also has some sort of knocking sound now and when you drive it, you get a lot of smoke. Truck is stock, 160k miles. Was thinking about throwing a race plug in it but not sure that's the fix.. Could the cp3 have taken a shit or what should I look for guys?
-08 LMM (Sold)
-15 LML with a few goodies
Old 03-01-2020, 09:58 PM
Burn Down's Avatar
Knocking and smoke are not good... I’d compression test it first. What are the balance rates?
Albert
04.5 CCSB ole blue, built trans, mpi twins, 12.5X @ 108
99' Reg Cab, 1500 2wd, Turbo or Procharged 6.0, 4L80E build inprogress
05 CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60
84' Reg Cab SB, 415 BBC, 4-speed, needs a D-max zf6 swap
Old 03-02-2020, 06:31 AM
Pwinland95's Avatar
Gearhead
Not sure on balance rates.. need to get a buddy over and hook up to find out
-08 LMM (Sold)
Old 03-02-2020, 06:36 AM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
I had this happen on a lly before. It was the injectors. It wouldn't build enough rail pressure to start. If you have it alittle sniff it would start but run horrible and smoke. Hopefully you disconnected the glow plugs before you used ether.
09 lmm ccsb ltz, moonshine, mpi s480 over 68mm vgt, sdp y bridge, BigDipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165 w/sump, isspro guages, traction bars, 3" drop shackles, the list goes on...Big thanks to BigDipper!
01 lb7 red RC/LB [email protected] MPH, SOLD
01 lb7 Black CC/LB, SOLD
Old 03-02-2020, 08:54 AM
Pwinland95's Avatar
Gearhead
Yes we disconnected the glow plugs..do you guys think with these symptoms that it could be the fpr?
-08 LMM (Sold)
Old 03-03-2020, 07:21 AM
KyleC4 KyleC4 is offline
Definitely have your buddy swing by and hook up scan tool. Need to see what kind of fuel pressure you’re building vs desired.
Concord Chevrolet
Mike L and Inglewood transmission
